Gloyale
86
Everything posted by Gloyale
Zero brake pressure unless pumped
Gloyale replied to ABawm 88 GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the car is 2wd you may just need to adjust the rear shoes. If not adjusted, the first pump of the pedal is just pushing the shoes out, and then on the second or third pump they actually hit the drum and build pressure. 4wd cars have auto adjuster....but it can be stuck.....or the rear shoes are way thin. I'd check into the condition of the rear brakes and adjust before replacing a master. -
	Check the connector at the fan. The Green/white wire in the connector should have 12v w/ key on. if it does, problem isn't the relay. problem would be in the reistor pack, mounted to the far front of the heater box, drivers side.....could be unplugged.....if it was just bad, you'd still have speed 4. If it doesn't have 12v, then probably is the relay. relay is up in the dash, drivers side.....look for the one with a fat white, and a kinda fat Green/white wire.
	I suggest the opposite. I've seen many 2.5's and some 2.2's with deformed covers. And some 2.5 sprockets that are just plain 1/2 notch off with the marks. The notches not reliable..... you can see this is the case in this threads pictures. lines on the belt are ussually more accurate. Although it's weird that the line on the crank is not on the right part of the ridge. still, i would say that it looks correct as is. Espescially since you can see there is slack in the belt, so when you pull the pin, the drivers intake cam will come into better alignment.
Driveline issues on 2002 impreza transplant into 87 ea82t
Gloyale replied to ea2ej fingers x's topic in Subaru Retrofitting
it's a cylinder on it's side, with a ball inside it. At the fluid entry end (back) there is a pin that keeps the ball from covering the fluid in hole. The other end has a "T" that splits the line sends pressure to the front right, and back left. (newer legacy only front left) When the cable get's pulled, the pin pulls back and the ball block fluid from escaping back to the master, basically becoming a one way valve. Now, if the holder is on a flat, or pointed downhill, the ball won't roll backward......ussually. there are a couple ways that it can happen and interfere with normal driving. 1) mis-adjusted.....level wise. Shim a washer or two, under the back of the holder valve........this will make it so you need to be on a steep hill before it will work. 2) roll backwards quickly, hit brakes and clutch.......ball rolls backward, locks brakes.......release the clutch once, and they should release. 3) very fast acceleration....slings the ball backwards......if you hit the brakes in this condition, with clutch in...locks brakes. any of these, should release when you release the clutch. I'm guessing you have or had the cable too tight. I would still suggest shimming a washer under the rear so it will not want to work on flats. worst comes to worst, it can be eliminated with a simple "T" fitting. Unless someone messed with it, the lines out of it go to the front left, and rear right. -
	That's pretty friggin sweet. Way to represtent yo:drunk:
	Slow jet is clogged somehow. take apart carb and blow out all the jets and emulsion tubes. replace the 2 tiny orings that seal the airhorns to the venturi ports
	Well, check that fusible link that supplies it first......it's the one most "in the middle" of the under hood fusebox. IF that's good.....gotta be the relay......it's Way up in the highest corner of the drivers side of the dash. It's brown, with 6 wires...mounted to a bracket with another 4 wire relay w/green connector(fuel pump relay)
	I'll bet you've got the strut blocks in backward. they need to angle in like this _ _ \\ // Steering take out the lower bolt, loosen the top bolt, slide the coupler up and rotate till straight, then slide it back down onto the rack stub.
	You need to bolt it to the underside of the tunnel. I've got 3" square block on mine. However, my shifter is cut and extended about 1" between the pivot and the linkage. This makes a short throw shifter. Before doing that the shifter was hitting the edges of the hole in the body, it had to travel too far. Also, I'm not using the 5spd D/R 4wd lever, I'm using the EA81 4spd 4wd shifter. The 5spd 4wd shifter is mounted to the base of the shifter....so I'm not sure it will work unless you can get that plate up into the cab again......which definately requires some extension.
	Yeah, wrong connector. Should be connector B82, 6 pins like this 1 .. 2 34 56 Blue w/yellow stripe wire, pin 5. connects to pin 6 on B56 of the TCU plug. Seems like you used connector B78, ......Labeled "Yellow", "data link" connector. Pin 5 of that connector is Yellow/red......switched power straight from Ig. relay. Provides power to the O2 heaters, pressure switching valve, and purge solenoid. That circuit is not directly connected to ECU...not as a power supply to it anyhow. So it's possible you just smoked the IG relay. Test the theory by applying turning the key to "on". Then, apply 12v positive to that same wire (yellow/red pin 5 of yellow data connector). That should power up the ECU, lighting the CEL. This will bypass the relay. If that works, then dig the relay out of the upper left corner of the dash, and replace it.
Rear Disc Conversion, Emergency Brake????
Gloyale replied to Naked Buell's topic in Subaru Retrofitting
Pull the handle......E-brake is on the fronts. -
Bad Head gasket, or Cracked head??
Gloyale replied to 85wagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The turbo ones will crack in the exhaust port. Never seen it in a N/A head, but perhaps if it got too hot. look in the exhaust port, and examine the area where the "bridge" that seperates the cylinders' port meets the walls of the exhaust outlet. -
Question about part on my 1993 loyale
Gloyale replied to Craigsti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Automatic seat belts -
	Hmm.....I never urinate in my gas, or pour it down the drain? I put it straight in the tank and burn it. Perhaps that's why you don't get better MPG? Dilluting it and then pouring it out? Or am I mistaken on the definition of "literally". But seriously you're just wrong about premium gas. Burns cleaner....and I've measured the MPG differences. Noticable power differences. Additionally, the new premium has little and sometimes no Ethanol in it which also helps with MPGs, alot.
Oily Engine Pics..Dumb question
Gloyale replied to Rick James's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pulling heads only exposes piston tops. On the motorcyle engine whole cylinder comes off the block....not the case here. A headgasket set is cheap. And it will include everything and you'll know it's been done. While in there, you can clean all the crusty carbon deposits off the piston tops. (a brass wire brush tool on a drill or dremel works great) GD.....common, really better to slap in some leaky junk yard engine with ?xxxK miles? I say you got 90% of the work done to get in and do HG's....so why not?
