hyphen
Contact Methods
  • Skype
    mark.putnam
  • Location
    columbia, sc
  • Vehicles
    02 subaru forester
hyphen's Achievements
Newbie
Newbie (1/11)
10
  1. as an additional thank you to anyone offering support on this issue, all i really have to offer is a some sourdough baguettes or hungarian apple turnovers that are habitually baked in my kitchen, so if any of yous are in columbia, sc- as long as i'm here and not in South Sudan, give me a shout and you get hooked up. thanks again
  2. thanks to all of yous for the tips and directions. and special thanks to Porcupine73 for the encouraging optimism about major electronics not being fried. the last thing i needed to think about was dishing out 1000$'s for a mistake of mine immediately after being critical of the wife wanting to spend money on ice cream. as it turns out, in one of the previous posts, i had mentioned(i think maybe) that the only thing that i did not test was the 80A fuse that looks like a fusible link. bingo. it was worse than the cinnamon roles that got left in the oven. this was at least the solution to the problem i caused, now onto alternator,starter,solenoid and other things like wheel bearings that may becoming slightly worn.
  3. With the ignition on: Fuses: Under dash: none get power Battery area: main fan, sub fan, H/L RH, H/L LH, do not get power.
  4. do you know the location of the 02 subaru forester main relay? is it underneath the driver side dash like 91 honda civic? thanks,
  5. 1. all fuses, minus the one that has nuts bolting it in have been checked healthy 1a. as they do not have names i am not sure which one is the "slow blow" 2. all relays have been checked healthy 3. three things work 1. horn 2. door locks 3. ding-ding-ding-ding.... when the key is inserted into ignition with door open 4. the emergency brake works, the front and rear windshield work, and the tires hold air, and the paint job collects pollen 6. anything else that might involve electricity does not work- no lights,no hums, no buzz, no clicks.
  6. incorrect battery jumping issue thanks for all the tips especially the Fusible Links. however, everything checks ok, fuses and fusible links. still everything in car unoperational.
  7. jumped my wifes 02 forester yesterday. while reminding myself + to +, - to -. while chanting this and staring at the posts to which i hooked + to -, + to -. sparks flew, cables were disconnected. now only the horn, door locks, and the beep the sounds with the driver door open and the key in the ignition work. also, when locking with the remote with the doors closed, a series of 3 beeps is sounded. before now, this only happened when the a door was open when locking with the remote. what is the most probable nearest component that i fried? thansk
