cobcob
Everything posted by cobcob
  1. Can I sue the DOT for salting the roads?? PLEASE?? Seriously, enough to make me cry over my poor lil Brat ya know??
  2. I reckon it'll never work, you'd better just give the whole shebang to me (car and all) and walk away:grin:
  3. Finally got around to uploading them!! Clicky
  4. FINE!! I'll measure mine when I get home tonight...
  5. LOL... that Toyo got NAILED!! I wouldn't count it as drifting though...
  6. I believe standard backspacing on the Toyota rims is in the neighborhood of 3.5"
  7. I've learned to carry a piece of wire with me. Has a female spade terminal on one end and the other end is stripped. That way if/when the key switch refuses to start the car I can put the key to "on" and jump the starter directly off the battery:headbang: Came up with THAT plan after realizing that talking her into starting doesn't always work
  8. He'd probably get that much for it down our way (SW MO) In the US prices really vary a LOT depending on what part of the country you're in... Tough to gauge!!
  9. You'd have to adapt a summit racing or similar universal gauge pod I think... Certainly not anything specifically for the hatch
  10. worst case you can order online through O'Reilly Auto parts (http://www.oreillyauto.com)
  11. Are you using Fel-Pro Permatorque head gaskets? I believe other brands of head gaskets (including the OEM ones) require re-torquing after a certain length of time...
  12. Comin' at'cha like a whirlwind... Courtesy of yousendit.com (file transfer website)
  13. http://www.kyb.com/catalog/2008_passenger_car.pdf 234046 - Fronts 341065 - Rears
  14. A HUGE thanks to Mellow Yellow for coming over tonight and helping me out!! Wound up being a combination of the timing being wrong and the distributor being shot. She's running great now!! Just have to bleed the breaks, re-fill the power steering fluid, find me some belts and I should be driving her real soon!! :clap:
  15. Can someone get me the a sketch of the profile of the rocker as well as a length? I can program the waterjet at my work to cut a replacement out of stainless, carbon steel, cold rolled etc. and then bent on the brake If there's enough interest I might be able to get a limited run done here for a reasonable sum! (I need a set for my Brat soon I think)
  16. I think you've got that angle covered! I'll go for the 6 lug conversion by drilling the hubs, slap some nice rims on her and a custom body kit... STREET BABY YEAH!! (more likely I'll leave it bone stock and drive her till she drops)
  17. I'm planning on getting into it tomorrow morning with the intentions of having her drivable by the afternoon! first step will be charging the battery up and then confirming that I've got everything set/timed/located properly... Fingers are crossed that I'm going to get lucky! Definately swing on by if you have the time! I'll be home all day!
  18. That's a European and Australian 14" alloy... as to where you'd get a set? Good question, I've only ever seen 1 set and that's on Roxy, Mykingcrab's RX sedan
  19. Joy's Brat... Interestingly, the first few appearances it was painted black...
