hey. hows it going, im kinda local... anyway i was wondering if you or any other forum members wana try meet up at effendal pass in tahuya o.r.v. over the weekend?
I have a 91 loyale wagon non turbo. And for some reason the coil/ingnition fuse keeps blowing. I put in a new fuse and can drive for a mile then it will blow again, i have no idea what to do, Any help will be greatly appreciated
Thanks alot,
Jason
I came up with no luck on how to fix it besides the ATF trick. But my noise started as soon as i got my motor back together so it must be some thing i did. Any suggestions on what i should do to fix this.
Thanks Jason
ok well i reconnected all of the vacuum lines. I had a few not plugged in. I went for another test drive and it still does the same thing but the intake piece does not blow off any more because i tightened real good. Once i hit 3k rpm now the car just takes off, it is fast and i know that something is not right.
Thanks Jason:banana:
I tightened it up real good and it works now but it seems like my turbo is putting out way to much boost. Because i have never seen a soob go this fast before.
Thanks Jason
I have a 87 gl with a ea82 turbo under the hood and when i get to about 3 grand the turbo really kicks in and goes for a second and then my intake thing that says "4wd turbo" the silver thing blows off above the throttle body. Then my car shuts down and i have to put it back on and this process repeats if i hit over 3k RPMs. Anything you guys think of that would cause this to do this.
Thanks alot
Jason
I just finished putting back together my 87 ea82t and when i start it it runs fine but the passenger valve lifters are making quite a bit of noise. Wll they stop by them selves or do i need to do anything that a might of did wrong when i put the motor back together.
Thanks Jason
I know someone that is towing 2 snow mobiles with his 87 gl ea82. Its about 1500 pounds. Is that too much weight for a soob. The hitch he has has 4 bolts that go into the bumper and 4 that go into the bottom of the cargo area in the trunk. Just curious if that is a good idea or if its fine.
Thanks Jason
My heads off my ea82 turbo are both cracked between the valves and exhaust ports. Can i get the cracks in the exhaust ports welded up and not worry about the other cracks. Who would be able to weld those.
Thanks Jason
