2
Posts posted by mkoch
*Two* Hitachis... my god, why?
Dang, I have the book somewhere, I will look for it. It has all the part numbers for 1984
- 1
7 hours ago, Ionstorm66 said:
"Without the hub on, there is no preload on the bearings. Re-install the hub and torque to spec. Now put the wheel on. With the car securely in the air, try to move the wheel. If you feel any slop or rattle, there is something wrong. Check balljoints and loose bolts first. If not, it's a bad bearing. " ....
I did this, I re-assembled the hub and wheel, and pulled on the wheel while it was off the ground.
The bearing feels tight with the 36mm nut tightened.
Thank you, group!
mkoch
A video where I ask the question:
Is this ok? Slop at rear axle, drum removed
The bearing can slide in and out with very little pressure.
Thank you, silverhelme
The engines on my 84 gl 4wd wagon, and my ‘85 Brat look pretty much the same.
Are the exhaust systems the same?
we Problem solved, thank you for the advice!
The problem was a hokey dash mounted aftermarket starter switch.
The switch is a rotational one, which breaks contact when the knob is rotated beyond the start position. The problem is, the switch has a fussy approx. 5 degrees of contact in “start” position.
My 85 Brat started and ran a month ago, then it sat for a month.
I tried to start it, the engine would maybe 1/2 turn over with each try.
Things I did
Replace battery with a proven strong one.
Clean battery terminals, and cable clamps, clean engine ground connection, clean positive cable connection at starter.
I can swap parts with my healthy 1984 GL!
What should my next step be?
On 1/23/2020 at 9:25 AM, skishop69 said:
For the majority, yes. What exactly are you planning?
When my '84 GL wagon frame rusts into nothingness, I plan to what parts I can on the '85 Brat.
You're in Oregon, this should be easy!
Maybe call these people.
https://www.facebook.com/pg/johnsubaruautobody/about/
They seem to have a lot of old Subarus.
- 1
The Y piece, catastrophic converter is available from RockAuto, and the muffler, surprisingly, available on eBay.
The piece between them, I guess called the “Resonator “ costs $180 from Autozone! Is this my only option?;
I am wondering if the 85 Brat uses the Generation 2 parts an 84 Gl wagon uses.
Make sure the stub the pre heater hose connects to is a true air heater.
Many aftermarket y pipes just put a dummy pipe there.
1984 Subaru, I want to be able to tow this one.
Should I connect the tow bar to the tie down points, (safe, secure)
or, to the bumper (convenient, iffy)
3 hours ago, DaveT said:
Look at the trailing arm. Does it have 3 bolts on the side? If it does that's the adjustment point. If not then it's a version I am not familiar with. A FSM would have the information.
There are three bolts, it looks like I will have to grind the holes to change the position of the bolts.
Can the rear alignment on a 2nd generation 4wd Subaru be adjusted by mere mortals?
Looking good!
Yes, the rust problem around here are horrible. I bought a California car, and it rusted in 12 years here i St. Louis.
I was able to tap the axle spindle out of the bearing housing... that was pretty easy!
”How To Keep Your Subaru Alive” does not mention that as an option.
A Youtube video shows tapping the housing back in to the spindle.
Can I do this without harming the CV joint?
This was answered in the duplicate thread.
Oh, and adding, the clicking noise happens mostly when decelerating.
If I turn hard, left or right, the clunking sound is not effected.
To me, that means the problem is the DOJ, (inboard) not the CVC.
mkoch
Thanks for the advice.
I brought the axle shaft/ bearing housing to a place that has a press, and they acted like it is a big risk to pop the axle shaft off. The tech said the axle shaft might be destroyed.
I am looking at another option...
Same old CVJ and bearings, new outer boot, but new DOJs and boots.
The mechanics here have me spooked about removing the axle shaft. Where would I buy another bearing housing?
I need to replace the front axle shafts. The seriously "clunk clunk"
I plan to replace a lot of other stuff while I am at it, such as tie rod ends, ball joint.
I have new wheel bearings and seals. The ones on the car seem to be holding up just fine. Replace them, or not?
'80-'84 part numbers
Posted · Edited by mkoch
This is from my 1984 parts manual. What does the module look like?
