2
Posts posted by mkoch
Here is a video:
The new and old clutch plates do not look the same. Will this be a problem?
mkoch
Thank you, Gloyale!
jono, how can I measure the crank case pressure?
The videos.... 22 and 24 seconds
I am trying to fix an oil leak at the rear min seal, but it looks like the larger ring isn't the thing that is leaking. It looks like an inner, orange ring is leaking, and that is not a part of the clutch replacement kit
What is the name of the orange rubbery part? I think I need to replace it, because it looks like that's the only place the oil could've come from.
Suggestions?
Does the oil pump need to be primed after I put it in?
The condition is:
I have a 1984 GL 4WD Wagon, and the engine is out of it.
The oil pump, and crank pulley are removed.
The front main engine seal needs to be replaced.
Can I replace the front main engine seal after I put the engine back into the car? I wonder if there will be room to do this.
That fussy little 3 bend hose which goes on top of the engine, available at Partsgeek! Also, the oil pump seal kit.
https://www.partsgeek.com/catalog/1984/subaru/gl/climate_control/heater_hose.html?brand=gates
Thank you for the advice!
Will "The Right Stuff" work for valve covers?
Oh, and the clutch was slipping. I thought it was a worn clutch
Thank you Sapper157!
Where should I buy the small coolant hoses, graphite gasket material, valve cover gaskets?
Also, I have not been able to find the valve adjustment tool for the EA81.
Thanks!
Here is a video of my oily situation.
I have disconnected all the stuff from the engine needed to pull it. I'm going to pull it tomorrow.
I will replace the clutch, and the rear oil seal. Is there any other easy convenient thing I should do while the engine is out?
Here is the image!
Here is a photo of an exhaust manifold stud which I removed.
There is aluminum stuck to about five turns of the thread, at the end.
What should I replace the studs with? The pitch is m10 1.25.
Should I tap the holes at 1.25, or drill them out and go larger?
Mkoch
PS: I second checking your clutch bracket. I went through 3 clutch cables before I welded mine up with some pieces of angle iron.
I will check it again. I am having trouble at both ends of the clutch travel.
The clutch will slip when my foot is off the clutch pedal
The transmission will resist going into gear with the clutch pedal fully depressed.
mkoch
Rock Auto has a few choices...
Is this a good one?
http://www.rockauto.com/en/moreinfo.php?pk=334557&cc=1268344&jsn=508&jsn=508&jsn=508
Thank you for the response.
The one I have now is a 1984 nom turbo 4wd wagon. The old one was a 1981 nom turbo 4wd wagon.
Is there a vendor for the clutch kit which is better than others?Edited, is ti likely I will need a new flywheel?
More on the symptoms....
I can make the clutch slip without touching the clutch pedal, at full throttle, 2500 rpm. It does not slip (foot off clutch pedal) at 4,000 rpm.
With the clutch pedal all the way in, the transmission will hardly go into gear. It is a struggle to push the stick forward when at a stop, putting it into 1st gear.
So, it looks like I can't solve this by adjusting the clutch cable, it seems to me to be a worn clutch. Opinion?
I may need to replace my clutch plate soon.
The clutch would disengage barely enough with the clutch pedal to the floor.
I adjusted the clutch cable so it is now possible to press the clutch pedal to he floor put the transmission into reverse without hearing the clashing of gears, but...
accelerating with the clutch fully engaged, it looks like the clutch slips. The RPM rise at full throttle without the expected corresponding acceleration.
I last did this job on a Gen 2 Subaru in 1989! I think I can do it again.
Please, I would like advice on...
Where to buy parts, including the insert to position the clutch plate
What other jobs should I do on the engine, as it will be out of the car, and easy to work on?
mkoch
BEECHBM69, hey, thanks!
Rock Auto sells about three lengths of clutch cable. What is the correct length for 1984 4wd gl wagon?
mkoch
Hello,
I am in the process of cutting out some rust from the rocker panels on my 1984 GL wagon.
I bought some 1985 Leone rocker panels, thinking they were the right ones, they're not. They are a little short.
I plan on using rivets, and carbon fiber, and , sigh, likely bondo.
Suggestions?
mkoch
I would like to know what these relays are. Here are a couple of pictures and a video.
Thanks for any help on this!
https://goo.gl/photos/WMvog46RqkaT4u8e9
https://goo.gl/photos/J11d48W25VJw8JFa9 -
This is the "before" photo. I took a wire wheel to the inside of my passenger side quarter panel, removed the surface rust, and then applied Rust Bullet.
I have learned from experience, it is important to attack any and all rust. It will only get worse.
I think I saved my quarter panel!
Video! EA81 pressure plate clutch, new, is this right? 1984 GL
Posted
Thank you, GeneralDisorder!
