scooby dooo
Everything posted by scooby dooo
Is it necessary to follow the recommended maintenace schedules? I have a used 2000 legacy, and I am unsure of the maintenance history. I asked about the 105k service at the delaer here in eastern mass and got a very ambiguous answer as to what it entails. Is this "valve clearance" inspection legit? I assume the timing belt/coolant flush/water pump needs to be done around now...brake pads maybe? The only things I've done to it are an exhasut donut and knock sensor. Thanks for any advice!
Thanks for the suggestiong. I don't think it is the knob, as I have been able to change the temperature a few times. I turned on the heat for the first time this week and it stuck on hot for a day, then it was OK. Then it spontaneaously got stuck on hot (while the switch was on cool) but also went away. Currently it is on cool.
I have a 2000 legacy 5 speed manual. It makes a subdued howl/humming when in first gear, disengaging or engaging the clutch at low speeds. Does not make the noise in nuetral or at higher speeds. The car is otherwise mint and was a good deal at 6700 with 95k. Any ideas as to what this noise could be?
LOL, I think you've all been had. I can't imagine anyone could write that without the old tongue in the cheek: not to fancy, not to bland. the rice boyz' girlfriends will be like.. whoa he's a hot boy! the subaru owners will be like, that sure looks supafly, and the punk in the jeep cherokee trying to cut me off thinking i have a slow pickup wont be able to finish his sentance as the rims blaze past the fibers of his exsistance on I-90!!
well it looks like I will be trading my 93 2.2 and a few grand for a 2000 2.5 tomorrow. I'm a bit leery but I can't find anything wrong with the car and it drives beautifully. My 2.2 runs OK but needs brakes, axles, struts, body panels and is poor on safety with no abs, passenger airbag (unless you count the wife). I'd really like to hear from anyone who has any tips on preventing HG problems...it seems obvious to me that I should monitor temperature and carry coolant in the vehicle. Please share any tips you might have on this vehicle O wise subagurus.
