Caramanos2000
Everything posted by Caramanos2000
Struts for my 87 Wagon
Caramanos2000 replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks man as always Will the Gabriel be better than my blown ones? -
Ok guys I need some front struts for my GL 87 Wagon. I found a set on ebay saying they are for a 90-94 loyale... Will these fit my wagon? The set if $70 instead of $180 locally:)
Help my car is Stalling
My mechanic told me it could also be the ignition module thats getting hot. Anyone have any ideas to test/and tips to swap out the alternator or the distributor? Forgot to say it has Throttle body injection. -
Ok my dad just called me and said the car EA82 Wagon is stalling while driving it. He says he waits a few minutes and it will then start and die again after a few more minutes :-\ What could be going on?
Documented: The 1970 FF-1 Project car...
Caramanos2000 replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Lol right... Could you describe the process your following? I just worked on my body and I didnt find it hard at all -
ea82 oil preference?
Caramanos2000 replied to BuddhaRoadkill's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use 10W-40 Castrol GTX with Some MMO in it Seems to work good for me -
ea82t it needs more power
Caramanos2000 replied to AWD TURBO!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
First he says 3 engines, then 13 and he has 8 lol. That adds up to 24 EA-82T Engines not bad jajajajaja. GD I think they beat you:banana: -
This has to be a joke, ok man you got us:banana: -
Its kind of sad when we all try and tell him his spelling is off and he neglects to spell check, even Firefox will do it for you Kind of sad my English isnt my first language and I live in Puerto Rico and my typing is still better than his :-\ I would be Immensely ammused by him proving 18psi on the 82T lol. I dont know much about the turbo engine but it sounds to me like your squeezing an orange and expecting apple juice to come out -
Dont forget he has a hood schoop to prevent fuel cut -
I might be able to help you man. What are you having trouble with? -
15" ATV 4X137 Load Rate 1000 lb Wheel
Caramanos2000 replied to Quidam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
$400 for a set of 4 shipped 2nd day air is pretty sweeeet. Will the backspacing work? Its just a matter of widening the holes by 1.5mm correct? What about tire options? Arnt these REALLY wide at 8 inches? -
How to: Incressing Boxer rumble? (EA82)
Caramanos2000 replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They do kind of rust, I painted mine with VHT header paint, actually I did my entire exhaust from the engine back with it -
Replacing the Headliner Material
Caramanos2000 replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No links sorry just head down to Autozone or Pep boys and look in the carpet section -
The kit in autozone of fabric is $12 -
Friend of mine did his with the headliner fabric kit sold in major parts stores and some 3M spray glue and it looks fantastic, I even thought of letting him do mine. It is allot of work though to remove all the moldings in order to get it right Good luck. -
Wow that stinks then a Turbo from Cherry bomb:) http://s104.photobucket.com/albums/m171/Caramanos2000/?action=view¤t=PICT4411.flv -
Go with a 2" straight pipe and if its too loud put in a Cherry Bomb glasspack or turbo muffle Mine sounds great with it -
Yeah it has a grownl but I think he means the distinctive sound of a Subaru Boxer. I know I can tell one without looking -
Swapping Shocks and Steering rack
Caramanos2000 posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok guys my mechanic told me my front shocks are going bad:confused: The right fron makes a clanking sound when going over small bumps and what not. I have a parts car id like to swap the shocks from and might aswell do the steering rack too. The shocks should be 5 or 6 bolts and im done. Any tips for the steering rack? is it going to be something better left to an actual mechanic? -
Well clean it up nicely and give some jb weld a go
intake manifold gaskets on ea82, 93 loyale
Caramanos2000 replied to Loyale93v's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just pulled one and it can be done easily without pulling off the throttle body. Be gent with the older hoses as they tend to brake. Make sure to clean all water passages and might as well remove the EGR and clean the carbon deposits out. -
I going to be pulling some parts from a donor, the include Shocks and struts Springs Steering Rack Power steering pump Power steering reservoir AC Compressor Alternator (Looks new but its a Hitachi?) Air Flow sensor air intake box I was wanting to clean up and restore everything I could before installing them into my daily driver. What paint would be adequate for these parts that would take the heat? Should I just use some engine enamel for the engine bay parts and some regular spray paint for the suspension and steering rack.
Im in Puerto Rico, dont know if you would still want a name and phone
