Everything posted by eppoh
I am trying to find a source for a rear baffle plate for my 97 2.2. Most of the online dealers diagrams bring up the oil pan baffle when I do a search. The one in this link shows number 2, but I think it is 34- right. Anyway, 34 is not in their catalogue. Are there aftermarket baffles available? http://www.shopsubaruparts.com/partlocator/index.cfm?action=getJointLocator&siteid=215738&Sectionids=10,0&groupid=10035&subgroupid=20091&componentid=60106&make=32&model=Legacy&year=1997&graphicID=F732055&callout=2&catalogid=1&displayCatalogid=0
I have never used silicone to make an oil pan gasket, but will need to next week. On the oil pan, is the bead run the full width of the pan mating surface, including over the bolt holes? Or do you tr to avoid getting the silicone over the holes/ That seems problematic if trying to make a good tight seal? I was thinking about an 1/4 inch bead all around, let cure for a few minutes, attach finger tight, then torque an hour later. You guys that do this often, chime in.
my 97 Lego has never made good fuel mileage since I have had it. It gets about 25 on the highway. My 98 with the same mileage got 28-29, before it was totalled. Yesterday, with the heads pulled, I can see a fair amount of carbon build up on the pistons and chambers. By fair amount, I mean more than any other I have ever seen on a 100K plus mile 2.2 Never had a check engine lights. compressions were always good 190 or better, kept in tune with Denso plugs, wires etc... All the cylinders look the same, so I am wondering if fuel pressure regulator could be the cause, or maybe egr. Anyone have a good idea?
While waiting to complete the engine swap oddysey on my 97 lego, I am planning to repair the heads on the engine pulled out. Got two zero compression cylinders after indexing the new timing belt wrong, and trying to crank it ( it never started) Don't know how only two cylinders were damaged. So I am thinking about trying to just replace the valves that are bent, but how can you tell if the valve guides are okay? I don't think surfacing should be necessary in this case
It does have an egr on it now. The engine came out of a 98 Impreza, so someone must have moved the egr over to it I guess. I also noticed that the baffle plate is metal, not plastic. I'm buying the engine from an individual who made a deal with me to install it as well. Thought I was buying a 98 with 130,000 miles on it. We are going to have to work something out about the price however. He's a nice guy, and I believe he thought it was a 98 engine, as he bought the car from someone else to part out. It was running and driving when he bought it. What is a fair price for a 95 motor with unknown mileage?
I need to move my 97 automatic lego, about a mile. Is it okay to pull it with a strap with the AWD fuse installed/ The only thing is the radiator is out and the transmission cooler lines are disconnected, so will the tranny turn and pump the fluid out? Does the key need to be on with the AWD fuse installed to keep the rear diff off?
Been waiting for weeks to change the timing belt on my son's 97 Lego. Wanted to do it while on vacation and take my time, but he couldn't so we did it today. I have never done a phase 1 engine before, and mis-identified the mark on the crank. I used the little arrow instead of the dot. Cranked the engine - no start. Retimed with the correct mark on the crank, and it ran- really bad. Put compression gage on it and cyl 1 and 2 are flat. I can't believe I did that. Was in a bit of a hurry, now it's gonna cost me, because I have to leave tomorrow to go to work and can't fix it myself. Looks like I'll be ordering rebuilt heads from 1st subaru or maybe Walker Subaru in Renton.. Since I don't know how many valve are bent, or if any guides are bad, I figure to bit the bullet for rebuilt heads. Machine shop prices here are going crazy high. So, Don't use the little arrow head on the crank gear! and don't use Haynes manuals. I told my wife, in all these years of repairing cars and airplanes, I have never damaged one- till now.
Kabuki idlers?
eppoh replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The seller emailed me and said Kabuki is a re brander of GMB and NTN parts. Sure enough, when I looked closely at the seals, they are stamped NTN. The water pump is Evergreen brand,. Guess I'll give it a try,
