Everything posted by subusolo2nut
Yes-I'm still alive--have had a "rough" year (too long to explain). Trex is without any rear suspension right now (parts in re-design, getting unequal A arms with heim joints & coil-overs)...The front reaction rods & lower inner joints went thru 5000+ street miles & 1 1/2 seasons on the track without problems. Currently have striped the car down another 230lb, almost moded the change to Miata front & rear calipers/rotors, re-designed the fuel tank location, changed the lug pattern to 4 X 100mm & several other changes:eek:. Net result: The EJ22/weber carb'd engine is about 190HP & the car projected final weight will be about 1600lb (1100lb on the front wheels) O--pics--If anyone wants them, just E me & I'll send them to you....(I need to track them down in my photo library)
EJ-22 into My '82 GLF Autocross car
subusolo2nut replied to subusolo2nut's topic in Subaru Retrofitting
No prob with the intake & carb--didn't work well in the winter here (needed a way to heat the air on the 28deg mornings:)--caused Carb icing on the venturis) a simple airfilter & heat-tube would work very well--just didn't work with a race engine---You would need a choke cable link on the carb (again, not needed on a racecar)--The only thing you need to do is mod the bellhousing (engine side) to clear the accelerator pump--I can shoot a pic of my mod--I'd take $150+shipping for the manifold/carb set-up--include the "milder"jetting so you could use it on a "stock" engine---The "y" pipe setup has been modded to work with the 2.2--I FINALLY got it running this evening--you should hear what two 45mm Webbers sound like on a 2.2!!!! I'd say that the induction noise at 6000 is around 95/100db!!! Gives me a case of "race face" just running it---I'd say it feels like 180hp--so, 1820+the difference for the 2.2 vs 1.8 and 105 vs 180--sounds good to me:) Anyway--if you want the manifold & carb--just E me autocrosser at macdialup.com -
Yes--It's possible--take a look at my other post on a EJ-22 into a '82 GLF autocross car--I used the offset housing from the driver's side of the engine (got another one from a yard for $10) & lathed a bushing to accept a EA-81 dist modified at the drive end with a honda dist drive dog--You need to slightly cut down the dist body end & inner shaft--the honda 'dog pins with a redrilled hole in the shaft (the 'dog is a floater--allows for "slight" mis-alignment) & set the front for TDC #1--The passenger cam from a early ('90/'94) has a offset slot made for the type of 'dog honda uses---I've got a pic of the housing mod & the modified 2.2--expecting 180/200HP with Dual Carbs.
No-The Dell is on the EA-81--I'll have the Frank'n'take & carb up for sale soon--The EJ-22 has a set of DCOE/9 45mm with 38mm venturies---Have you contacted Alfa 1750 on eBay for your jets? There is a place in So.Cal. (don't have the address) that I know about--I can try to get it for you if you still need it-- T-rex has been consistant all season--I've been invited to Thunderhill next year to "play"--So-the EJ is going in this weekend & I get to sort the carbs out before the next solo event (Sept 11)---wish me luck!! -
Well--I've not posted here in almost a year--the world & life in general as usual--happens. In any case--I know that several people have wanted to know how to mod a dist into a EJ-22---I'm here to say you can & here's how. Most of the earlier EJ-22 cams have a offset keyway cut into the passenger cam rear--This area is covered by a "blanking plug" that has two ears bolting it to the block. This "plug" IS EXACTLY THE SAME layout as the cam offset carrier on the front of the other head (see the first picture) I cut the excess off the extension & machined a bushing on the inside to match with a "normal" dist shaft diameter--I have modified a EA-81 dist to fit--you need to shorten the shaft & body length & use a Honda offset drivedog. I'm re-curving the dist to use centrifical advance only--you can use the vaccum if it is a street car--next you will need to find "true" TDC & mark the front crank pulley--align it with the marks on the T-cover.. O---And I'm including the other picts just so people can see a 200HP CARB'D EJ-22
Well-It's venturis--and the DGV series carbs are a cast assembly--so changing the size requires changing the carb--the jet assemblies are the changeable parts--I work with replaceable venturi carbs (DCOE & IDA carbs)--harder to work with due to the varables, but much more tuneable---
Front/rear main seals
subusolo2nut replied to Mendodave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What I think that he is refering to is known in the US as a "Redi-Sleeve" made by several seal makers--It's a very thin steel sleeve that is gently tapped on to the pulley sealing surface--you normally start the sleeve on the pulley & then set a piece of wood on top--tap the wood with a hammer & "drive" the sleeve over the surface--I normally drop some LockTite on the grooved area for the new sleeve to "bite" onto--Check with a local parts store to see if one is availible for you application---I'm not sure one is--- -
Its been a Month & 1/2 from these pics--You can look for the lower control arm mods that were in a later thread---With proper thought you could use this mod for both raised & lowered cars--Raised cars would need the inner fulcrum point rotated to align with the control arm & lowered cars can do it like the pics show---As for the handling---First, steel parts transmit more road noise to the inside--that being said--You can place the car almost anywhere in a corner & I feel totally at ease running 3 times the "rated" speed thru a corner--the car plants within a inch or so of where I want it to & the line thru is changeable at will--I've been invited to run the car at ThunderHill next spring, so the EJ22 & the rear suspension mods have pushed the paint job to the side--I'm going to design a 8 to 11 gal tank to go under the floor in the old rear seat area so the rear can be just for the exaust & rear suspension---With no rear tank I'll be able to design a wide-based A-arm suspend--will have adjustable coil-overs with rear discs--moving the tank forward in the body will also increase traction under acceleration & inprove weight transfer under braking--Going to be very busy the next few months--I'll have pics as it goes along--- Dean
having problems which sucks
subusolo2nut replied to bajavwnsoobnut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
First off--The choke element should be at 12V or so--I've cut the old wire at the connector before & ran a new wire to the positive side of the coil--not a problem one after--This worked on both my '85 hatch & '84 GL Wagon--they both had the same prob at one time or another--- Dean -
AW CRAP!!! Hang in there man!!! Feels good to put it to the Wrx's!! I was generally 2/3 sec faster on the course than those boys & they couldn't understand it----As for the gaskets--I'd talk to the NAPA boys--I got to admit I use only mama Soob--I've had too many probs with the others--but, that's water under the bridge--LUCK TO A WAY HOME!!!! Dean---
Gotta have some Old School Representation....
subusolo2nut replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
YEA to that!!! I don't care if it's high or low--IT'S STILL A SOOB & WE NEED TO PROMOTE IT TO EVERYBODY!!! -
T-Rex's A Arm Mods!!!
subusolo2nut replied to subusolo2nut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I forgot to add--as far as control is concerned--I think that I am the better judge of what I want in terms of handling instead of some designer sitting in a office far from where the car is being used---I know that the intent of the car is far from what the designers were intending--- -
Wow!! In a Ideal world, you would want minimum camber change over a large suspension travel--a almost unheard-of state of being--In reality, working between positive & negative 3 deg during "off-road" work with a neutral (read zero deg) camber during street work is good enough--The prob is to get enough travel, you are most likely starting with a fair amount of positive camber--not very good for normal street use--to get lots'a travel & keep minimum camber change, you need long control arms---half the vehicle width is about as short as you need---if you could have lower suspension points at the trans center-line & use the normal strut uppers--you would be heading in the right area--this is not taking into consideration clearance of the arms--blah-blah Sounds like a interesting design study--- Take a look at the Baja 500 runners--the suspensions are INSANE!!! -
Anti-Subaru Zone.....:(
subusolo2nut replied to matrixops's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry to hear about that---BUMMER!! The wife & I (she had FINALLY realized that I NEEDED a race car) bought the GLF for $400 from a little old lady in Jacksonville, OR--of course, it helps that this was our 5th Subie---Keep lookin'--they are out there-- -
OK--quick alignment info---Camber & toe-in/out are the most important adjustments in front & rear of a car--Negative camber means that the tire lower side is out more than the tire upper side, all measured from a 0 degree point--the more negative the camber, the more "resistance" to tire roll-under during cornering--Most race cars run in the 1 to 2.5 degree negative area--the downside is increased tire wear & a "heaver" feel at the steering wheel. You can reduce the "heavy" feel by decreasing Caster--the amount positive or negative that the tire pivot axis "inclines" fore & aft in the body--I don't know very many (if at all) cars that use negative caster--positive caster is used to "straighten" the car after a corner--when you turn, this is the value that "resists" the turn--wanting to straighten the car back up....Race cars decrease this value close to zero (slightly negative) to help the driver work with the negative camber--as you see, the two values need to be in harmony to allow the car to "work" with you..Lastly toe in/out--again this is a value that work either way--toe-in provides a "self-centering" action as will toe-out--toe-in is mostly used in rear wheel drive cars because the front is steering & suspension only--when you add front drive, its better to toe-out slightly. So in my case--.5 negative camber is for cornering force--almost zero caster "helps" me by reducing steering effort at the loss of "self-centering" (which I DON'T want anyway) & I keep the toe close to zero to put most of my power to the road without "scrubing"(too much toe-in or out). Now that I've got everyone yawning---- Hows that for a kind'a answer---- -
Yea--I'm a roadracer type--but you could use the set-up for offroad--use the greased heims--as for the size, they are the 1/2" #8's--The ones in there right now are commercial grade--I had them at the shop--I've got a high-strength set on the way--The tubing is DOM--got it & tube inserts from Art Morreson in Auburn, WA. (drag racer supply)--The thought process was the longest part of the design--welding & fab just "fell" into place once the plan was set-- I'm going to re-design the rear suspension next--un-equal A arms with rear uprights from mid-80's Nissan Maxima--I get rear disc that way & get rid of the heavy torsion bar tube:brow:--also allows coil-over shocks with adjustable ride height--- I'd say go ahead & set-up your car this way--the control over the front is MUCH better-- -
Brat with no fuel!
subusolo2nut replied to ledhedsymbols's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Fuel Pump Control Unit looks at the tach signal & keeps a relay closed to supply power to the fuel pump--Fed mandated to shut the fuel off if the engine stops for more than a pre-set period of time (about 30sec)--I have replaced it with a Chev Vega oil pressure cut-out switch (opens a circuit when the engine has zero oil pressure)--this "switch" & a relay works better than "uncle sam's" mandated idea---use the "switch" to create a ground for the relay--Relay powers fuel pump--no oil pressure=no fuel pump---simple:) Second note--earlier cars used the alternator signal to trigger the fuel pump relay--I can't remember the year that Subaru changed to tach signal--I know that my '82 used tach not alternator pulse for the trigger--- Dean -
Please help me make a decision....please
subusolo2nut replied to pwoens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK--so it's got 156k or so--I'd want a stick--the auto has a interesting solenoid to divide power to the rear that the stick does not--I've replaced 10 of the units in the last year--the stick usaes a third "diff" that is mechanical-- Second--there are four idler wheels in the timing case & the waterpump that should be replaced at 120K + the seal to the oil pump has been upgraded by Subaru--I bet they were not done & the total for the four+ waterpump is kind'a high-- If you want the car bad enough----go for it, but remember what it takes when you open the front case-- Dean -
Hey OZ-Land-Man--The first arm took about 2 hrs & the second was about 40min:grin:--most of the time was translating the thoughts/drawings to real life--I've posted the radius rods about a week or two ago--might look at my prior posts--ditto the exaust mods--the handling is BITCHIN!!! Just took a corner that is "Labled" 25mph at 65mph---without anything other that just driving thru it--if I tried, I feel sure that 80mph would be easy-- -
OK--I finally got the time to put T-Rex up on the lift to shoot the pics---took TWO days for the line-up shop boys to have the time to fit him in--Specs right now are---Zero toe---.9 positive caster & .5 negative camber---when I work up a mod to the rack & tie-rod ends to allow more adjustment, I'm going for .75 negative camber & zero caster--not enough adjustment in the stock stuff to allow that much change----in any case, here are the pics---I still need to make spacers for each side of the Heim joints---that's why the washers--we needed to know where the proper set point was---
This is likely to get some mixed responses
subusolo2nut replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well-In the collection of useless data--I have a answer for this one-------- are you ready------ Skinner's Union--and why they would make carbs--any guesses?? -
Well-I'm a old Dual-carb school person--Please no flames, but I'm setting up a dual 40mm Dellorto set on the EJ22 going into T-Rex (and no, I'm not using ANY electronic parts other than a dizy--mechanical advance only--). For sheer guts-out-in-your-face, you can't beat multi-carb set-ups:grin:, and I like the set-up (yea, I know---I'm CRAZZZZY)--So--YES on a Balance tube--the bigger, the better--you want the carbs to "swap" gas:brow:--the bigger the tube, the less you need to syncro the carbs--they should be the same as much as possible of course. And a GOOD dual carb set will run very close to a multi-port FI system--you just need to know HOW to set them up RIGHT--- So that's my two cents worth--- -
MUHUHAHAHAHHA~!!!1~!!!one!!!~1!eleven!!!!
Yea-I understand the last minute thrash--When you get back look at my message & let's get all the dimensions down & i'll cut you a set--If the OD is the only prob--that's no sweat--- Kill them this weekend!!! I'll post the pics of mod #2 for the front of T-Rex tomorrow or Saturday--- Dean
