3
Everything posted by suberdave
there are 2 different sizes of shafts that came on the GL's. i beleave they are 7/8" and 1" the smaller of the two will fit right into the inner cup of Legacy shafts. you just have to check spline count. but i do have an extra set of the races that i used when i mated my JDM WRX LSD R160 to a set of XT6 shafts. pull your axles apart and count the splines and i can tell you if they will work or not... -=Suberdave=-
Late 90's EJ seats into L series - anyone done before?
suberdave replied to el_freddo's topic in Subaru Retrofitting
I put JDM STI seats in my GL\L series\Leone... I just pulled both seats apart, and used the frame and rails from the stock seat, now i have STI seats with higth adjustment... -
you could go and get a speed sensor from the tranny of a newer EJ car, and wire it up to give the signal to the ECU. of course your spedo will not work at all. but you wont get limp mode... im not sure if you speedo is working now or not, this may not matter...
I have thought about this many times... i even have a set of projectors in the garage. glad to see that it works.
Bypassing the hillholder
suberdave replied to thebr0wn0ne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you can always go to the junkyard, find a car with an auto trany. and take the whole front section of the brake lines. they all unbolt at unions, and it is super easy to swap. no more hill holder... -
want to put an ej18 in my ea81 BRAT, HELP!!!
suberdave replied to tallwelder81's topic in Subaru Transplants
PM sent -
here are some pictures of how i put Rear Brembos on my GL. it would be the same for Legacy or Impreza rear disk onto any GL. but like Tex said. its finding the rear hub that is the hard part. they are not easy to find. http://wordpress.suberdave.com/?page_id=59
I have an EJ18 sitting in my garage, i will install it into your car wire it up and everything. you drop it off, you drive it away. PM me if interested...
first off. i have been running Xt6 axles in my 1996 WRX front knuckles for about 40K now with no problems at all. they fit right in and i have not had any issues. as for the outter joint. to remove it you have to take the inner joint apart. then find a metal tube that the axle shaft fits into. (it must be longer than the shaft by a little bit) then smak it onto the ground a few times. it will pop off the shaft and it will be awesome...
the 6speed will not fit in the brat trans tunnel. unless you lift it a bit...
R180 3.9 Diff needed , what interchanges?
suberdave replied to Scott in Bellingham's topic in Subaru Retrofitting
if you are putting an R180 into a Brat. check this out. sould be the same as putting my R180 into my R160 Wagon http://forums.nasioc.com/forums/showthread.php?t=2048240 and http://forums.nasioc.com/forums/showthread.php?t=2039248 -
Wated: DOHC EJ swap engine bay fitment pics
suberdave replied to Mudpup's topic in Subaru Retrofitting
here is a picture of an 87 GL coupe (RX) with an EJ20G in it. more pictures at http://wordpress.suberdave.com/?page_id=110 here is an EJ in my Wagon. -
Any one have any pictures of lowered EA82's?
suberdave replied to flyjum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
since this thread is still going, i will post some updated photos... more pictures at http://wordpress.suberdave.com/?page_id=162 -
Washington subaru owners
suberdave replied to r81gsr95's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have done a few swaps now for other people. i am located between Seattle and Tacoma. If you get all the parts. and bring your car and parts to me. i will install everything, cut down the harness and have it set to drive back to your house for around $1000-1200. depending on what all you want done. i am an ASE master certified auto tech. and have done more than a few EJ swaps. both EJ22s and EJ20Gs into older cars. as well as EJ207's into 90's Imprezas. PM me if interested. ill give you my #, and we can talk... -
how can i tell if 2.2 engine is interference motor or not
suberdave replied to deepbluehawaii's topic in Subaru Transplants
I could be wrong. but i thought the interference 2.2l had single port exhaust and the non-interference 2.2's had dual port exhaust... -
in an EA82, just get a WRX pedal box. pull the 4 nuts off of the brake booster. pull your old pedal box out. drill 3 holes in your firewall. 2 for the bolt holes and one for the clutch master to go through. bolt it up and bleed it... i have done it a couple of times. not bad at all. here are some pictures of my old "RX" that i put an EJ20G into. http://wordpress.suberdave.com/?page_id=110
More Info: what car is this going into?
Here is what i currently have on my car for the 5Lug swap Front: 1996 JDM WRX Knuckles 2003 JDM STI Rotors 2003 JDM STI Brembo 4Pot Calipers 2005 Legacy GT Tein Flex Coilovers 1989 XT6 Lower control arms 1989 XT6 Sway Bar 1989 XT6 Axles SS Brake Lines Drag D4 17" wheels W/ 205/40R17 Nitto Neo-Gen tires Rear: 1988 GL-10 Trailing Arm 2003 JDM STI backing plate W/ Working Parking Brake 2003 JDM STI Rotors 2003 JDM STI Brembo 2pot Calipers 2005 Legacy GT Tein Flex Coilovers 1989 XT6 Sway Bar Custom Hybrid Rear Axles (to run R180 Rear Diff) SS Brake Lines Drag D4 17" wheels W/ 205/40R17 Nitto Neo-Gen tires Whole Car:
Any pictures of EA81/82 with shaved body?
suberdave replied to aaronxs400's topic in Old Gen.: 80's GL/DL/XT/Loyales...
again... no shaved body parts. but this is my wagon. i like to think it is prety clean looking. Not to mention full STi Drivetrain with 306AWHP and 335AWTQ... Sitting on 205/40R17's more info and pics at www.suberdave.com -
Where can I find this corner light?
suberdave replied to Duraznov's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sorry the one that i have is different... -
does the orange go all the way across the light. or does it have a little bit of clear all the way around the orange lends? i may have one. -
If you shoot some starting fluid in the intake then crank it, will it fire? do you have spark? do you have injector pulse? with the Turbo ECU? have you tryed swaping the NA ECU back in and firing it again? -=Suberdave=-
how about this one... EJ running gear into Nissan Hardbody... http://forums.nasioc.com/forums/showthread.php?t=2053013
thats what im saying hince the "new car project"
