Mike_N_Austin
Everything posted by Mike_N_Austin
Correction to my last update I accidentally disconnected a vacuum hose the other night when I was adjusting the Throttle Position Sensor. I re-connected this hose last night and now the MAP sensor fault is apparantly gone Drove the car 45 miles on this mornings commute....and so far no codes Will see what happens at lunch. But, at this point, looks like knock sensor was the culprit.
:mad: AAARRRGGGGHHHH Check Engine light came back on. Ran the codes at Autozone. Now the MAP sensor is coming back faulty. No O2 or misfire codes...yet....so at least those may have fallen off. But...MAP sensor is a $ 200 part. Questions for the experts: (1) Can the MAP sensor be cleaned ? (2) Will outer Barometric (Sp?) pressure impact the readings of the MAP sensor ? We are having some wicked weather in central Texas today...so I am holding out hope that maybe this is possibly causing the issue ? (Or is that a nerf bat statements ?)
UPDATE The Knock Sensor is in. Took it for a test drive and the "knocking" has definitely gone away at high RPM. So I am 99% confident that the original sensor was malfunctioning. I disconnected the positive battery cable. Will let it sit 3-4 hours to reset the computer. Please Please Please.....I hope the check engine light stays off
Good news....I did fix the loping idle. I cleaned and adjusted the "alignment" of the Throttle Position sensor. My car used to have a very eratic and loping idle.....would bounce between 500 and 1,000 RPM. It was very annoying. Now the car pegs at 750 RPM and idles like new. I removed the TPS and cleaned thoroughly with throttle body cleaner. But when I first re-installed it back into the car and took for a test drive, the car ran very rough...almost like I was getting severe mis-fires and backfires. I then "advanced" the alignment of the TPS all the way to the other side.....and the car ran better....but would stay locked at high RPM. Specifically, if I put it in second gear and ran it up to 3,500 RPM and then I changed into 3rd gear, the RPM would stay pegged at 3,500, instead of quickly dropping during gear change. So I then reset the "alignment" of the TPS to center and it ran much better, and idled much better. So I am not sure if it was the cleaning, or the realignment or both....that has fixed my idle problem. But...if you are having a loping idle...I definitely recommend cleaning and adjustment to the TPS. (Throttle Position Sensor) The car ran better than I remember it ever running. I seem to have more power and acceleration. I am hearing a lot of "knocks" and "pings" at high RPM....so I am hoping that the Knock sensor will improve the performance even further.....and allow me pass inspection
LOL But I was told here and other places to inspect for cracks. There were no cracks. I have also read and heard that just because you get a fault code on a part it does not necessarily mean that that particular part is actually failing. The code could be an effect of another downstream or upstream cause. So I am really leary about throwing money at parts if I don't know for sure that they are faulty. I have done this many times in the past.
Well...I pulled the knock sensor last night and inspected it. There are no cracks in the metal end of the sensor. I cleaned the sensor with throttle body cleaner and I also cleaned the contact point on the block. I then re-installed the sensor. I unhooked the ground battery connection and let it sit overnight. When I started it up this morning..the darn codes were still there....they never cleared. I also removed my idle control sensor and cleaned it with throttle body cleaner. I have been having a rough loping idle when in neutral. After cleaning it...and adjusting it....I now have a smooth steatdy idle. I will post this under a new thread for future searches. On the state inspection...I am going to try and get a sticker in a different county. My county is only 1 of a handful in Texas that is holding to the new emission standards
Nipper...Again....THANKS !!!!!!! Looks like I need to start with the Knock sensor then. Can you tell me where it is located and what it looks like ? I understand that is is located somewhere close to the throttle body...but I cannot locate it. Do I need to remove the air cleaner box to see it or to get to it ? On the Knock sensor...dealer is quoting $ 103.79. Best quote aftermarket is $ 80, so far...but nobody has stock.
Thanks Nipper I experienced a very rough idle shortly after I did the HG. It ended up being broken spark plug wire. I ended up replacing the wires with a new OEM set. I also put in a fresh set of NGK plugs. I read somewhere that the plugs have a "crush washer". Perhaps i did not install my new plugs plugs tight enough ? I also remember replacing the front O2 sensor...but my memory could be mistaken on that....(unfortunately I do not keep good records :-) ) I will definitely inspect the knock sensor. Question - is the knock sensor a sensor that can become clogged.....in otherwords, would cleaning it possibly fix the problem with that sensor ?
My State Inspection is up and they will not give me a stick if the check engine light is on......or if the computer reads a recent hard code fault. I took to Autozone and got the following - Misfire on 3 - Misfire on 4 - Faulty Knock Sensor - Faulty forward O2 sensor (the one located closest to the engine I have a 2001 Subaru Forester with 191K miles. I pulled the engine and resurfaced the heads last year at approx 175K miles. The misfire codes have existed since that time.....the Knock and O2 sensor codes are fairly new. Please help !!! :-)
Two other options that work. (1) A 3/4" or 1/2" Impact Wrench will take if off in a jiffy. (2) Or you can secure the pully with a chain vice grip. This is a handy tool that has a bicycle chain instead of a plier nose. You wrap the chain around the socket and close the vice grip. This works well if you cannot afford an impact wrench.
