Everything posted by Suba9792
Check your knock sensor as well, I have heard that it can cause poor fuel economy not sure on that but mine is getting better mpg since the replacement, odds are yours has never been replaced and its most likely cracked, RockAuto has OEM ones for about $50. I'd also look into your coil as well, they tend to not fail but mine was biting you when it was touched, after the new one no probs and noticeably better fuel mileage. When I changed out my PCV valve on my 2.2 it was very gummed up and so was the hose leading to it, I just used some brake cleaner and cleaned out the hose and dropped in the new valve and my idle smoothed out greatly. Odds are you just have some dirty old part that either needs replacement or cleaning(EGR).
GD said the tensioner was ok, are you talking about the hydraulic thingy? I got the kit from Import experts. Its a 97 lego. Ive done the seafoam job through the intake. Should I try it in the oil? The oil pump plate was checked and all was well. am I right about the whole rod bit though? rod knocks get louder as things heat up in my experience.
Any one have trouble with piston slap lasting more than 10min on an EJ22?, mine seems to do it for about 20min of driving and then it goes away, sometimes its still present after 30min but slowly goes away. At first I thought it was a rod knock but I'm pretty sure they do not go away and I would hear it at idle as well. This one seems to be only while accelerating I get the light tap,tap,tap in conjunction with acceleration but not while decelerating. New T-Belt job done by GD Fresh oil change Mobil 1 5w30 New OEM knock sensor new OEM plug wires and NGK plugs New(used)5MT with new Exedy clutch & TOB rebuilt OEM front axles New coil pack new battery I'm just stumped on this, I though piston slap only effected the ej25d but I might be wrong. And a rod would not go away and I'm sure it would tap,tap,tap at idle as well if that were the case. I'm just not sure how many miles I will get out of it with the slap. It just started 6 months ago, but it did it when it was cold before but recent months it takes a LLLOOOONNGGG time to dissipate. Hell I have even tried different grades of fuel to see what that might due, and nothing. please let it be piston slap and not a rod:eek: maybe it will lighten up as summer approches.
I think(hypothetically) that I figured it out....its the tires, they are super soft and there is a ton of of grooves for the winter traction. There is a reason why I think this, I had to go to OHSU to pick up my grandfather today and had my brother and my son in the car, along with a ton of medical supplies for my grandfather, with the added weight there was no drift so the tires IMO were planted to the ground more. I guess I'll just get some decent new street tires and see if that happens to work. Kinda want these Toyos to last a few seasons:lol: I didn't have this problem until I put these tires on, but I think I will still do new tie rods JIC and the other ball joint.
just an idea... if you want an imprezza but cant afford a WRX, here is the other option:banana: find a decent imprezza with a ej25d, the find some ej22 heads talk to GD and get the torque cams. That car will scoot!! its know as the "frankenmotor" dada da, there ya go. GD has built one and is in the process of another for his GL(it will be scary).
I have replaced the rotors on my 97 Lego twice.. I live in the mountians so its a normal thing. Most of the shops around here charge at least $25 each to rotate them, I head to the closest parts store and viola! $25 each for brand new ones..so yeah you might as well pick up new ones as the cost of turning them will be about the same. Shiny new parts:banana:
