2
Everything posted by darsdoug
My guess is there has to be some type of restriction in the oil passage's or possibly intermittent low oil pressure? I've seen this before when I was a teenager. Might as well have been during the Crusades for some of you. ha ha. The standard 1950's FoMoCo Y-block V-8's were notorious for it. Lack of oil getting to the rocker shaft assembly's resulting in squeaking, clacking, poor performance and eventual failure. Let us know what the cause of the problem is when you get it figured out.
Top of the bore on the end of compression stroke. Roger that.
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
First one I've split to check out rod knock damage. There were no signs of a rod bearing left on #1 other than a good amount of metallic powder inside the oil pan. It was another learning experience for me to say the least. The phase-1 94 Impreza block I swapped in last June is holding up good. It was a cheap 150 dollar EJ22 I'd found on Craigslist.
Yes, new HG's will in fact raise compression to a point where the piston rings need to be up to snuff. I'm old school and I received most of my knowledge from a seasoned auto mechanic while helping out at a Texaco gas station in Seattle back during the summer of 1967. Last summer I helped my son-in-law put new Six-Star HG's on his 99 OB along with all new valve seals and machine surfaced heads. The EJ25D only had 136K on it but it's been going through a fair amount of oil . We determined there was no smoke coming from the tail pipe plus no oil dripping anywhere, so we've been at a loss as to where the oil was going? My guess is the rings?
PSI is PSI in my world. Nevertheless I could be wrong.
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
Is there a reason for putting shop air to a suspected leaking cylinder at TDC instead of when the piston is at the bottom of the bore ?
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
Perfect. I think I'll start doing that. Perfect.
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
http://best torque bind explanation There is a thread started by RallyKeith back on August 11, 2005 you should probably try to view. I can't seem to create a working link at this time for you.
- 5 replies
- AT Temp
- 1998 Legacy
(and 2 more)
Tagged with:
From my past experience with domestic engines I'm fairly certain the front journal on the crankshaft is too far gone. The only evidence of it ever sporting a rod bearing was a bunch of metallic powder inside the oil pan. I need to get a crankshaft kit with pistons, rods, crankshaft, rings and bearings. I might just shop around for another good used 99 shortblock? I've been running with a 94 shortblock since last summer and it's doing o.k.
Composite HG with frankemotor (ej22e heads, ej25d block
darsdoug replied to MilesFox's topic in Subaru Retrofitting
I think you should try them regardless of my own selfish curiosity whether or not the higher compression will cause them to fail?
