Bostonian1976
About Bostonian1976
- Birthday 04/21/1976
Vehicles
I Love My Subaru
Bostonian1976's Achievements
Member (2/11)
0
Everyone's favorite code! Mine doesn't come on for a good 300 miles after reset but it does eventually come on So far I've done air filter (very dirty), plugs (.060 worn instead of .044) Next I'll do o2 sensors before surrendering to cat Here's my question. The dealer tested my o2 sensors and said they're cycling. Could they possibly still be bad or does that 100% exclude them? Thanks!! This is a 2000 Outback
Hi all. Still sorting out my 2000 Outback The steering does some clunking over bumps etc and I get a clunk when turnin the wheel left or right (just a slight clunk) If I grab either wheel - especially driver's side - I can replicate the clunk when pulling the wheel left-right with my hands What is this and how do I fix it? Thanks very much
lights blink slowly? yeah your siren is missing or connection is cut, and the alarm is ''SOUNDING" but you can't hear it To get the lights to stop flashing, or kill the alarm, turn your ignition on and hit the small button at the base of your dash on the far lower left. There should also be an ignition kill while this is happening, unless that has been disabled as well (it was on my 98) there are several connections that go into the black box - make sure they're all connected to get your locks working (a remote program procedure needs to occur as well - you can find it on cars101.com)
okay successfully fixed my heated seat switches! Radio shack only had one pair of bulbs, so I had to choose what to fix. Sadly - it seems I somehow broke the filament in BOTH indicator bulbs in the process - so now they light up at night, but don't indicate on-off....the opposite of what they used to do!
I went through this successfully with my '98 Legacy. do you have the black box to the left of the driver's leg when seated (may be tucked up in that area)? Also should have a small pushbutton mounted at the edge of the dash near your foot (tricky to find). This was a CodeAlarm system, and it did have a siren under the hood - not sure why you don't have one (maybe removed?) My dealer had cut the cables to mine because it seems he couldn't figure out how to make it work you can program the remotes yourself (for the second poster) and you can also turn the chirp on/off with a microswitch located on the black box itself (but you'd need the siren for it)
I'm in the process of 'rejuvenating' the '00 Outback I picked up. As far as bulbs, I noticed: - the indicator bulb for the heated mirrors is out - the whole right side of the instrument cluster (temp gauge, tach, etc) is out - I'm assuming this is just one bulb - how hard is this to change? All switches on the left (fog lights, heated windshield, and cruise control) are out - are these meant to light? Thanks!
Just wondering what I can expect out of my 2000 Outback's 2.5L? It's been well-maintained - just leaks a little at the oil pump, which I'll take care of when I do the timing belt. So - assuming average maintenance prior to my purchase, what is typical high mileage from a 2.5L? 350? I'm presently at 250k. I just changed the oil and it DRAMATICALLY quieted my piston slap in 25 degree weather - amazing difference. Car feels strong and runs well. Next change will be plugs, air filter, diff fluid, trans fluid
