kevinsUBARU
Everything posted by kevinsUBARU
I have the same problem on a 2001 Legacy L wagon, 5-speed, 73,000 miles. I was told that the power steering hose assembly is the culprit alot of the times (from a shop owner on NASIOC). Insuficient pressure due to restrictions in the hose cause the pulsation, and it's about $155 for the hose and an hour of labor to fix. I was also told that it's a sign of a dying power steering pump and/or fluid may be low. Take your pick, whatever you choose, it's most likley something related to the power steering pump. That being said, I haven't fixed mine yet, and it's been doing it since last winter. Take care, Kevin
I have a 2001 Legacy L wagon. I really enjoy it. No problems except a whine during startup at cold temperatures, and of course the HGs. I bought it with 48K. The first cold snap of the year with temps hovering at -10F got the HG leaking at only 58K. I had the coolant conditioner added, and it worked for a little bit. At 68K, during the first cold session of the year (not below zero) it was leaking pretty bad again. Full warranty replacement on HG and related items, a new oxygen sensor, and timing belt for $76. I say just check it out good, and go in for the kill
A year ago, I installed the Kartboy short shifter and shifter bushings on my 2001 Legac wagon. The bushings are cake to install, especially if you roll the car up on some ramps. I found it very helpful to wear a backpacking head lamp while changing these out. The difference in feel is amazing:clap: The NHV noise went up very slightly. Then a couple of months later when I had a new clutch installed, I had a USDM STi tranny mount installed as well. These are found on nasioc.com for something like $30 shipped, and they make a night/day difference in the crispness of your shifting. NHV noise seemed to be very loud at first, but has since quieted (or I got used to it). No complaints from passengers, and it's fine when cruising at 75. Kevin
I didn't read the whole thread, but I'll add my two cents... Even the cheapest snow tire will be GREAT on an AWD Subaru. I ran Hercules Polar Trax for 3 seasons on my Impreza, and I am on my second season of Winterforce tires on my Legacy wagon. Cheap (As in around $300 mounted), they wear well, and plenty sufficient for fun and safety as long as you keep that little thing called common sense. Kevin
So here's the scoop: The left and right side gaskets are getting replaced as well as some other related stuff under warranty. The dealer, who I feel is honest, also noticed oil leaking from the timing belt covers. I have seen this drip before, but I kind of just always forgot about it. Anyhow, the front oil seals are leaking, and there was oil on the timing belt, ect, ect. So I am also getting a timing belt job and all of the other related stuff for $280. Then subtract my $100 suby bucks and thats $180 for a pretty refreshed engine:) I'm not psyched that it happened now, but I guess it would have happened eventually. I close on a house first thing in the AM, so what's one more check to the Subaru dealer
I believe you are looking for a 5 bolt wheel (5x100) and not a 4x100. You also have to take the offset into condiseration. I have seen VW and Dodge Caravan (I think..it was a Dodge) rims used on Subaru Legacys before. However, since Subaru has a magical offset, you may kill your wheel bearings faster if you use something other than Subaru. I believe that the range of "safe offsets" is something like 48-55.
Rally New York - September 22-23
kevinsUBARU replied to kevinsUBARU's topic in Meet n' Greet. Your USMB Welcome Center
I just learned that it has been cancelled unfortunately...not enough enteries:confused: Cross your fingers that the one in April will still go on... -
Just a hare over a week to wait..mmmmm...rally...... -
Skid Plate
kevinsUBARU replied to moo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I ran a Primitive Racing plate on my 1995 Impreza, and when I switched it over to my 2001 Legacy L, I just had to drill new rear mounting holes in it. No biggie:banana:
