bork
Everything posted by bork
Anyone hear of this dupont material? http://www2.dupont.com/Automotive/en_US/news_events/article20091005.html Are the usual boots made of rubber? neoprene, nitril, silicon, EDPM? I emailed Dupont & awaiting answer. Where are the billion , long lasting boots, they boast? I'm changing my mind about Dorman, looks like they are universal, & 2 piece? (Not very fond of 2 piece, but maybe I'm too old)
Thanks! I was leaning towards Dorman, lifetime warrenteee? Rockauto had a heart next to the name. I'm not familiar with Beck/Arney, but looks like you do. BTW I see something about rebuilt cv axles, I knew a place that regrinds them & installs larger balls. I personally wouldn't go that route, because I would think the hardness is changed on the regrind surface.
wow, thanks for rockauto tip, the boot prices much better. I saw subiepartsforyou, & saw approx $39 per boot & thought foolish? to not change axle, but now I can justify fixing existing axles, they are still quiet. BUT which brand is the longest lasting? I see in search that some aftermarkets were torn in little time. Any name brand known for quality?
1999 impreza L at front struts are leaking & therefore I hope to replace my self.( best struts for the buck?) Since both sides will be taken apart, should I just put two new axles in at the same time?(since inner boot is torn?) Do they come with boots? Whos last the best for the buck? Also need seals on both sides of tranny front axle output.
well I picked up the one at Advance & it looks tweeked/twisted like it was dropped on corner, but no signs off actual damage. Debaiting , & favoring not to install. Dont want to do twice. (lifetime warrentee or not.) Is there any temp sealers that are ok to use to buy time. I told dude at counter , to bring in another & none in stock, nor at distributor! So now after seeing Radiator Barn delivers to door for a better price! Hmmmm, anyone else use the Barn? Feedback please.
This new to me 2.2 has the same slight knock at idle, especially in gear (lower rpm) But I changed everything at once. Oil/filter, TB and pulleys & waterpump, thermostat, drive belts, and flushed AT tranny last. I didn't notice mine either before all the work. But I still wander if the guy I bought it from had a bunch of additives in oil to silence it? Other than that it runs great!
I ordered from a place out of ph book on a 800#, for my 97 honda odyssey. I compared it to the one in van & looked way wimpy. Did not want to chance the install (I complained) & they refunded my $. So I went to my Advance auto prts , & asked to look at replacement & it looked looked OE or a great copy & they have lifetime warrentee. So I took it & thats been a little over a year ago with no problems. In that same time I replaced my Ford diesel powersrtoke with another Advance radiator & I am pleased. My .02 On edit; I just looked at replacing head light bulbs & saw green weeping at top crimp of rad, & not the upper hose leaking down. Bummer! Looks like I'll be calling tomorrow am for a rad also. Wish there was a way to tighten crimps.
Is this sensor location, a good place to try a manual gauge? If yes, What are normal pressures for a 99 2.2? (warm idle) ever since I changed TB & waterpump & all pulleys, & changed oil /filter, (10w30Castrol & OE filter)Seems like there's a slight thunking at idle, & more noticeable when put in drive. (due to lower rpm?) Old oil was nasty from the PO, maybe they doctored oil up to hide sound for me, the sucker?
