jimmyberka
Contact Methods
Website URL
http://
Location
Seattle
Referral
I have been a member before
Biography
Self proclaimed shade tree mechanic
Vehicles
1990 Subaru Legacy wagon
Recent Profile Visitors
jimmyberka's Achievements
Advanced Member (3/11)
11
I’m changing out the transmission on my 1990 Legacy L AWD station wagon. The # on my transmission is 3V-TY752VA1AA The # on the one I got from a wrecking yard ( supposedly from a 1992 Legacy) is the same except at the end of the id# it is AA2A instead of AA1A,. does anyone know if these two transmissions are interchangeable? Thanks, Jim
I DID clean the surfaces very well, and used a dealer supplied gasket. I did not have the head machined,and also did only the drivers side, so it looks like that is my next step (machine both heads and install new gaskets again). I had the bleeder cap open and filled the radiator through both the bleeder valve and the radiator cap when the engine was warmed up, but it is still blowing water out of the filler neck when I rev the enging at operating temp. It sure seems like I have the air out of the system. If I drive it a bit affter warmup, the reservoir will be filled to the top and the temp guage quickly shoots up towards hot:Flame: Thanks for the help, Jim
A friends '92 legacy was overheating and blew a hole in the radiator. I determined the head gasket was leaking because air was pushing a lot of water into the overflow and the engine overheated quickly. A Compression test showed all cyls (except #4, drivers side rear, which was 80-90) at 140. After replacing the head gasket on only the drivers side, I now have 140 psi compression on all cyls., but still have air pushing coolant into the reservoir and engine:Flame: overheating. Any suggestions on what to do next? It looks like I still have a head gasket leak even though compression has risen on the #4 cyl. Jim
