Posts posted by Bantum
I've been following your posts on FB - great work ...
Do have a query on how much stuff do you have left ?
Ciao, Bantum ... -
I do, but would be best to find someone local ...
Have you tried a hacker space ?
Cheers, Bantum ... -
There be wiring diagrams floating around somewhere here, on FB & AUSubaru ...
I like the mag wheels you had on earlier, hope you kept them ... :/
Did some measuring of my own 5MT & R160 Differentials :
Nice to know they are not the same ...
I'm doing some research on the R160 diff project & came a cross this thread, would be be interested to know if a locker could be made to fit both front & rear carriers ...
Follow the project here : https://www.facebook.com/R160.Diff.Locker.Project/Cheers, Bantum ...
The 'R160 Diff Locker Project' has been started over on FB, you're welcome to check it out & fill in the survey.
We'll be looking at making a prototype eventually that can be field tested, then it should be available for production.
More info here : https://www.facebook.com/R160.Diff.Locker.Project/Cheers, Bantum ...
- 1
Looking for pictures of the new hub ( not previously posted ) + it would be good to see some install pictures to ...
Thanks for the offer Dean, PM sent.
Yerp - The 5 speed may not fit in the tunnel, as is a bigger unit than old one + the EA82 is wider & will require rail mods.
I'd get both drivelines & lay them out, once you have them side by side & note the differences - you'll see what will / wont work.
Yes you could cut the tunnel & rails from a donor - lot of work though. P.S. - You'd want the strut towers as well.
Ciao, Bantum ... -
Yer, I'd go with an EA81 for a direct swap, anything later will require modifying ... :/
If you do have your heart set on a later model, go for EJ SOHC gear as it should fit without too much trouble.
May also require 'massaging' the tunnel, depending on which transmission you use ...
Yer - it'll be easier to replace the whole line, as you'll be forever chasing rusted spots ...
Hub redrilling is not ideal in my book, so I'd go with the 5 stud conversion ...
Cheers, Bantum ...
Not sure what your after exactly, as this site is more for car engines ...
Link to supplier : http://www.ramengines.com/page6.php
Cheers, Bantum ...
You could just un-plug it ...
The metal 'innards' of rear bumper may well be crushed / bent. hard to tell unless its removed for inspection.
Missed you all too ...
- 1
Bit of an early Christmas pressie :
Not sure what I'm going to do with it at the moment, but do stay tuned ...
Ciao, Bantum ...
- 1
Go Fund Me :
https://www.gofundme.com/subaru-xvute
Will give this a go & see what happens ...
Ciao, Bantum ...
Yes compression test will tell if rings are good ...
Are you sure the smokes coming from inside the exhaust ? As there could be a leak externally dripping onto it ?
Could be just a loose wire, You would need to take the dash apart in order to fix it though.
Cheers, Bantum ...- 1
Yep - Have a read of this :
http://www.ultimatesubaru.org/forum/topic/160706-rear-differential-locker/
Cheers, Bantum ...
Far as I know they are in 'testing' mode, so will most likely be next year sometime before we know any more.
P.S. - That's in AU so will be like $600 to $800 US ...
Cheers, Bantum ...
- 1
Haven't heard of any that will fit, as Subaru splines / diffs, etc. are all different than a Toyota ...
So it will need to be a custom job & may not be worth the hassle.Ciao, Bantum ...
New seats = more space?
in Historic Subaru Forum: 50's thru 70's
Posted · Edited by Bantum
If you're after a new seat, can try the BRZ / EA86 seat - They have been successful by all reports for later gen BRATS ...
Not sure if they'll fit in earlier model though ...
Cheers, Bantum ...
