matt167
5
Everything posted by matt167
Did he change the cam/ crank gears from the original 2.5? Most of the EJ20's you find are from 2002-2004 ( EJ203 most common ) models and use different parts in that respect.. They work just fine in the older cars EXCEPT the triggers are different and you need to swap parts.. The EJ201 would be the one you would not have had to do that to but they are getting harder to find. Most now list them all togther.
They had to get some $$ back somehow you know.. Valve guides dropping isn't common, but it happens. I would wonder if it actually happened to yours. Those parts are cheap but labor intensive, so high dollar profit for the shop/shops involved... $105 for a donut gasket. that's laughable. It's 2 bolts, and a $20 part. If you break the spring bolts they are not that expensive even from a dealer.. $105 for a radiator hose, yeah really silly there. Consider this, By them 'covering' one HG, they are agreeing to remove and replace engine, so you are getting a several hundred dollar discount. I'm sure they flat rate the time, but I'm not sure how many hrs flat rate it is for your model to R&R the engine. It's probably like 4hrs though.
Tires older than 10 years are considered expired, and they can't be sold past 6 years of their DOT date. Tire shops can't do anything with them past 10 years of their DOT date and will accually recomend discarding after the no sale date for safety.. Date of install DOES NOT have any effect on the tire age and shops are allowed 6 years to sell them.. Tires start 'getting old' right after they leave the factory.. You'll see DOT on the tire, and then some letters and numbers which are part of the DOT code, and then the date code which is the week and year.. If you have a 3 digit date code, that means it is older than 2002 IIRC.. The Full DOT code should include the manufacture plant, a code for size and dimensions and then the date. So any tire essentially has a VIN number and can be identified where it came from and what it is. You can contact the manufacture for DOT decoding Even at 6 years IMO, that's pushing it for tire age. You can tell and tires 6 years sitting in a store room, they look pretty shot.
When my 2001 Forester first started having some trouble w/ a light backfire and routinly blowing a cloud of smoke when cold, I bought my JDM EJ205 swap. I bought complete w/ trans, turbo and intercooler for almost exactly what the local wrecker wanted for a 150k+ mile EJ251.. Since work picking up among other things, I didnt get the chance to swap before cold weather.. I figured the EJ251 was still running good, and the miles keep piling onto it. Currently sitting at 232k with some change. No knocks except cold piston slap, occasional backfire from deceleration and lots of smoke when it's cold/ first start, but once it's clear it just runs great. It has not taken more than 1qt of coolant since I did the timing belt, probably 15k miles ago.. I've been hoping it would just take a dump one day and I would HAVE to make the swap.. But it's just not going to. Trans has a slight issue with 4th grinding on a downshift but it might be just me. It goes in fine, just gives a slight grind noise. It shifts tight and direct otherwise Is there any value to the EJ251/ stock 5spd and diff? I think the smoke is oil entering from the valve seals on shutdown, or a head gasket allowing the same.. I'm sure heads need rebuilt and head gasket swap would be about mandatory on it anyway.. I use one extra quart of oil ontop of a 5qt jug to keep it full within a 3k interval. So approx 1.8qt of oil is 'used'. Other half, does not see the light in a turbo swap when the stock engine could likely last the life of the car... And I know she wants the short block for herself, cause her EJ205 is about pooched ( engines need oil, a concept she can't seem to grasp ). But, NAH. I bought it for me
