I have a hesitation problem that gets worse with fast acceleration. And can completely go away at times with normal driving. Car will cruise at 60 to 75 for hours and then act up as you slow to 40 to 50. Gas pedal acts like an on off switch. Not really noticeable under 40. Also idles high in gear and sometimes shifts erratically when cold. If you take it out of gear the idle drops to normal. (Auto transmision) Changed TPS, Maf, cleaned EGR (it works) cleaned IOC.(Closed at idle) Checked and replaced vacuum hoses. Replaced fuel pump and filter. Checked fuel vent line from tank to engine. No vacuum at idle from canister to EGR. New plugs and wires. Never found vacuum at idle at purge control solonoid, press. reg. or press. sensor. Auto zone checked, - no codes - no light. Wiring to eng. computer looks fine. Going to change timing belt when I get the chance. Car has 188,000 miles on it. I know the previous owner, he got rid of it for this problem. I'm at the point where its costing to much to fix. I still believe its a manifold press. problem. But I am now lost. Any suggestions would be appreciated.
