smartdriver
About smartdriver
  • Birthday 03/21/1965
  • Gender
    Male
  • Location
    The Netherlands (Europe)
  • Interests
    Streaming audio, my VW
  • Referral
    Mid engine setup
  • Biography
    48 years old, in the proces of totally rebuilding and upgrading a Brazilian '69 VW splitty with a mid engine setup.ATPLEAD
  • Vehicles
    '69 Brazilian split in major overhaul
smartdriver's Achievements
Newbie
Newbie (1/11)
0
  1. I'm with you on this Tsuru, you'll blow up this tranny if you do as mentioned. The centrediff is not supposed to handle that much power in the way you discribe. There is another way to do this, almost bullitproof. You have to split the gearbox of its rear drive and make it 2WD. There are aftermarket "nuts" to lock the rear output shaft but there is a cheaper way tot make this happen also. You take the centrediff apart and weld some parts together to make the same locknut as mentioned above. LOCKNUT and more: http://www.subarugears.com/Products.html DIY locknut: http://www.914world.com/bbs2/index.php?showtopic=104513 I hope this helps. Cheers from the Netherlands, Paul
