			jgrimm
				Posts29
Everything posted by jgrimm
	I really think its an axle once in awhile well most always now when I get above three thousand rpm in first gear I get a tink sound from passenger side front. Its a fast tink tink and it will stop for split second once in a while like it caught then it continues. Or could be front diff.hoping its axle
	Ya but I just want it done enough that someone will buy it for two grand with the paper work. If I move the shifter in first gear it only vibrates once starting out. And then moving it to second while in second I can floor it without any problem. Then I move shifter to third n drive with no problem.its just starting in first and as it shifts to second
	Think m my shop should just be able to pull the first and second gear bands and replace them?? Cause of no burning fluid and no metal shavings the first and second gear bands could just be bad from being heated?? Cause its only those two gears giving me problems until I above 15mph or unless I floor it so it drops gears into bad second gear
	Well towing it would have kept it UN first gear.that could be why first and second are bad cause they use gear bands that touch each other. But honestly when I was changing fluids to narrow down problem it looked like the fluids had been recently changed cause of dampness around drain bolt from draining it
	Was towed with front tires on car dolly. Car in neutral with steering wheel tied straight. And just drive it again. When it starts vibrating and juddering when you accelerate moderately our harder the tachometer does not bounce. It stays moving like it should. And doing sixty just cruising their is no problem.but if you floor it once it drops into lower gear it starts shaking bad with no weird noise, just shaking and it slams into gear and felt like it bounced out of gear before it caught again but it stayed in gear. Its just trying to accelerate it happens n once out if second gear does not take much effort to keep the car accelerating so shaking stops is what it seems
	Hey my fiancee did tow the car 146 miles from where I got it from cause her friend did nit wanna drive it back. It was in neutral with steering wheel tied in place. But fluids and diff fluid looks like had been changed before like previous owner tried to find problem n could nit. I got car off auction.
	My shop says that its almost half a second before car goes into gear every now and then. He said if it was u joint shaft wood almost be falling off. He wants to tear it apart. Ha. That's 1200 right their to have it dropped and pulled apart. But he thinks cause it turns almost full revolution before catches sometimes that it can't be u joint. I dunno. I'll check it out if it does not rain
