schspeedster
Location
PA
schspeedster's Achievements
Advanced Member (3/11)
10
'93 Legacy w/195K purchased w/mismatched tires. Replacing w/new set of 4 did not correct torque bind. Draining pan & refilling auto trans fluid fixed the problem. Several drain/refill cycles may be safer than trans flush on worn trans, trans flush solvents may flush out too much crud at once and cause Bad Things to happen.
The Impreza costs and weighs less than the Legacy. Any big tradeoffs besides back seat room, like ride comfort, noise, vibration? I am over 6'2" and the Impreza wagon drivers seat actually seems roomier than the Legacy. And how about resale value? 2005 Impreza 2.5 RS Sport 2976 lbs / 165HP@5600RPM / power-to-weight ratio 18.3 Front headroom 38.6 in / Front legroom 42.9 in. Dlr invoice approx $16862 2005 Legacy L 3200 lbs / 168HP@5600RPM / power-to-weight ratio 19.4 Front headroom 39.5 in / Front legroom 44.1 in. Dlr invoice approx $19678 stats from http://theautochannel.com/
Any list of items to check / replace with strut, so as to have new parts on hand ? For example: Strut mount Boot Spring (is there a dimensional check to see if originals OK?) Related parts Sway bar links & bushings Brake lines Drive axles Ball joints Tie rods Any grinding of the mounting holes needed to give room for alignment shop adjustment?
I want one! Have an unused ruggedized aluminum suitcase, and tools scattered around the garage, need some foam rubber that can be cut out, so every tool has its place. http://www.subaru-msm.com/global/feature/letterSWRT/15.html http://www.swrt.com/440096.html And the Ultimate Subaru Portable Garage Maybe Rally is one reason why most everything on a Subaru seems designed for ease of service. Some of their engineers could have had to actually lie on the ground and use a wrench out in the snow, to get the car back in a rally. http://www.swrt.com/cpimages/671924.jpg http://www.swrt.com/cpimages/678316.jpg
How to determine engine & drivetrain condition by inspecting a non-running car? Any external signs of destruction besides a big hole in block? Spark plug condition or soot inside exhaust a good clue? Do crash impacts kill the motor from mechanical shock, even if the engine compartment is intact? I assume an experienced tranny tech could drop the pan and make a decision based on debris in pan. Next question, how many men and what tools to bring to pull a motor at the U-Pull-It junkyard?
