Everything posted by Mr.Atlantis
I would say anywhere between 4 and 4 1/2 hours shop time. Assuming that it will just be a clean swap. If a rebuild is necessary, you may be looking at around 10 hours and much more $$$. $2000 for parts and labor sounds about right, also assuming that the $2000 includes the used tranny. I got all the above times from my AllDataDIY.com account. The car referenced was for my 08 Outback Legacy. Labor time should be around the same. New transmissions could be in excess of $4000. Hope this helps.
I never took the gears out of the case, I just unscrewed the caps to get the oil seals and o-rings out. However, the gears inside were in my opinion free-floating in the case when I took the caps off. As in, I could have easily removed them, or turned them and whatnot. When I first started to unscrew the driver's side, I had the transmission sitting in it's 'as installed position', and I noticed a beveled gear trying to follow the cap out as I unscrewed it. I quickly turned the case on its side to allow gravity to hold it in there. I was refering to the axel cups and bearing orientation earlier.
I got to thinking... When I replaced the axles, I also installed new Oil Seals and O-Rings. I counted the turns when I removed the retainers and was sure to re-install them the same. As to not allow the beveled bearings to fall out I replaced one at a time by turning trans on to side allowing gravity to keep all gears and bearings in place. Would noise come from my case if this 'lash' adjustment wasn't performed absolutely, dead nuts perfect? I mean, even if I knew the exact gap between retainer and bearing surface - how could one even get an accurate measurement? It's a sealed enclosure once installed Could I give each side an extra 1/8 of a turn tighter in hopes of fixing the chatter? Or would that introduce a whole world of messy stuff?
I can double check nuts, but I should probably mention that when I slipped the axel side cover off to remove old grease - the 3 bearings fell on the table and I completely lost the original positions. I installed them correctly, but bearings may have switched or flipped. Damn thing was too greasy to hold let alone keep track of bearings.
Re-packed and booted my orignal Front CV axles last month due to both Trans side boots ripping. I went with the Re-pack option because I was weary of inferior parts from over-seas. They just started clicking last week. So bascically I wasted my time and now I'm going to need to purchase something. Any "tried-and-true" suggestions on some budget axels? On Rock Auto's website I can get some A1Cardone's anywhere between 60-80/ea., Napa gets around 135 (after core)...Yadda yadda, feedback time. Thanks in advance.
EA?
Mr.Atlantis replied to Mr.Atlantis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thank you for the detailed breakdown. So it's 4th gear that is closest to my 'direct' drive-line huh? I was always told it was 3rd.- 5 replies
- Transmission
- motor
- (and 4 more)
EA?
Thanks, I'll give it a looksie.- 5 replies
- Transmission
- motor
- (and 4 more)
I see talk of EA this and EJ that. I'm assuming these are the Trans or Engine types of the particular vehicles in discussion. Does anyone have a complete list with matching years and models (or at least OEM installation)? What is under my stock 2008 Legacy Outback 2.5i 5MT? My transmission is labeled: TY758VCABA-GA (which is about the only ID I could find on it.)
- 5 replies
- Transmission
- motor
- (and 4 more)
Hard pull when braking...
Mr.Atlantis replied to Mr.Atlantis's topic in Non Soob Cars and Bikes Discussion
I would have to imagine that whatever the issue is, it would be similar on any vehicle regardless of make, correct? -
Is this a year where the Fuel and Filter is a combo unit?
- 7 replies
- hesitation
- outback sport
(and 1 more)
Tagged with:
1999 Mercury Cougar V6 2.5l Scenario 1: Hands on Wheel Pulls very hard to the left when braking. After letting off the brakes - the car will immediately straighten itself out. Scenario 2: Hands off the Wheel If traveling in a straight line - Wheel turns to left when braking as if some kind of auto pilot has been engaged, but the vehicle continues in a straight path. After letting off the brakes - the wheel straightens out. Once again, maintaining a pretty straight path. Obviously Scenario 2 is undoubtedly dangerous. We have temporarily learned to counter steer while braking. Terrible thing to have to learn. Any thoughts on where I should begin? One of Front Struts? Rack or Rack bushings? Tie-rods? I’ve already replaced Calipers, Pads and Rotors all the way around the car. My initial thought was a hanging caliper. Kind regards
I just recently dealt with a similar issue. I was getting very little power and it would shutter on acceleration. I would actually have to floor it in 1st gear to make it up hills. I replaced the downstream O2, MAF Sensor, Spark Plugs and Wires, and treated my fuel. Nothing. I had someone rev the engine while I cupped my hands over the exhaust pipes and realized very little was escaping. It never triggered the appropriate codes because it was clogged in an un-monitored resonator/cat thing built into my intermediate pipe. However it did randomly trigger lean A/F ratio type codes (which is what made me spring for the downstream sensor and MAF). The fix (for me): Removed intermediate pipe, attached wire coat hanger with several twists at end to my battery powered drill and aborted the filling into a shop vac. Immediately fixed my issue. It actually has more power now than when I purchased. WARNING: My car's intermediate pipe was un-monitored. This could present a serious issue if done to a vehicles monitored converter.
