Stevo F
6
Everything posted by Stevo F
As for the engine cranking a while before it started, that likely was due to the ECU reset they did to shut off the check engine light. Our 2005 Impreza was getting a Check Engine light for an evaporaitve hose leak and when i reeset it the car would crank 10- 15 seconds before it started, but that never reoccurred.
When filling up our 2005 Impreza Outback Sport (2.5 liter N/A engine, 5 speed manual) a couple of weeks ago I noticed the car has to crank a long before it started. I recall having a propblems on our '98 Legacy like that and it was the evap purge valve (mounted on the intake manifold). I thought this might be the same issue here, but after the next fill-up, the car started right up. My wife drove it about 80 miles today and told me she got another CEL (we just had to replace the upstream O2 sensor a few weeks ago). This time it was a P0457 (EVAP System Leak Detected Fuel Cap Loose/Off). I tightened the fuel cap and reset the ECU. Code gone for now, but when I started it it was hard to start again. Restarted again a few minutes later, and it it started fine. I also noticed when I let off the gas (in or out of gear) the idle sometimes drops to 500 RPM or so, then goes back up to around 750 where it normally is (idle is smooth). With the hard starting and this code, where would be a good place to start looking?
Still could be an O2 sensor. Our 2005 OBS had the check engine light on an off a few times then finally stayed on all the time. I have a code scanner which told me it eas the front (upstream O2) sensor. In our case, the car still seemed to run OK, but in many cases, the car will perform poorly (ropugh idle, low MPG;s) as without a functional O2 sensor, the ECUre tunes the car into a default limp mode. I ended up having to have our mechanic change the sensor because someone had apparently cross- threaded the last one. New O2 sensor is in and no more CEL. Incidentally, if you replace a Subaru O2 sensor use Denso brand as these are OEM.
- 8 replies
- check engine light flashing
- subaru outback 2002
- (and 4 more)
Actually I looked down from the top and I do see a sensor on the front side of the cat- so is the is the fron O2 sensor then? I also bought a 3 piece 22MM/ 7/8" O2 sensor socket set on Ebay. I figure one of the three sockets/ wrenches shoudl get it off. Biggest concern I have is that the things will be rusted in place (this is a northern car). Shot soem PB blaster on it already and will warm it up before I attempt to remove the O2 sensor tomorrow. Anyone have any other advice?
Since we bought our 2005 Impreza OBS a year ago, we had slow leaks in both back tires. Actually the used car place probably never checked them as I found the left rear had 12 lbs. and the right rear has 22 lbs. Over the next few months the left rear continued to have a sloe leak. We had a tire place reseal the bead which helped for a few months but then it start leaking 2- 3 lbs. of air a week. The right rear started leaking at about the same rate as well. Since the tires were mostly worn and very noisy on the highway I had a new set put on. Sure enough the right rear was still losing 3 lbs a week. I took it back to my mechanic who installed the tires for us and he resealed the bead and installed a valve stem. Long story short, after all this the right rear tire is still losing 2- 3 lbs a week. This after replacing the tire, the valve stem and resealing the bead. Where else could this leak be that hasn't been fixed or replaced already?
My wife has been driving our OBS, with N/A EJ253 engine, and told me the Check Engine light has been coming on and off intermittently. I pulled a P0131 code tonight "O2 sensor circuit low voltage bank 1, sensor 1". Based on what I've read, this would indicate an issue with the first O2 sensor in the exhaust manifold (or its connection?). If this is cause, can anyone tell where exactly this O2 sensor is located, and the best way to get to it? Also, are there any other causes that would throw this code?
Hello- I have a 2014 Impreza (sedan). I think you'll see a decrease in MPG's this time of year because of different gasoline formulations due to colder weather. In my case (I have the CVT but drive it manually only occasionally) I've been running 32- 33 MPG in mostly longer trip driving (I have an 80 mile round trip commute) but am seeing 30- 31 MPG in the past month. It also takes your engine longer to reach operating temperature in the cold weather (I am noticing the blue temp light is on longer nowadays). That being said, your MPG drop seems pretty steep. Were there any other changes to your driving/ or the car around the same time? As for tracking gas usage using the gauge, I calculated each bar on the fuel gauge= 1.2 gallons. With my driving, I drop the first bar at around 560 moles after filling up, the second around 90, the third around 130. When it drops 6 bar (at 1/2 tank on the gauge), I usually am down about 7 gallons at that point. I find the MPG's calculated by the ECU to be 2- 4 MPG higher than what I'm getting, but I see those MPG's drop drastically when the car is cold or if taking it for a shorter drive, then gradually climb back to where it was after a longer drive. After what I've read about warranties, I'm a little gun shy about making any mechanical mods to the car at this point. (I did opt for the 100K mile warranty this time). I've started same my oil and filter receipts for warranty purposes in case anything were to happen (never did anything like that with previous new cars). Probably just me being paranoid from reading stories on these forums).
No snow yet here in Northern/ Central VA, but as I noticed my 2014 Impreza being a little squirmy going over a small patch of ice today, I got to wondering if the newer model Subaru's with CVT are as good in the snow as older Subaru's with the 4EAT automatic or 5MT manual equipped cars (I have one of each of those). I plan to use the paddle shifters to downshift (like a manual transmission) to better slow the car down without using brakes on ice and snow, but do the CVT equipped cars handle in snow as compared to the older cars? We also have a fairly steep driveway that goes uphill to the road. If it snows, you need 4WD or AWD to get out (should I assume my new Impreza will have no trouble)?
Thank you all for the advice and suggestions. I'm looking at different tires and tire reviews at Tirerack. Given I'm looking for something decent for $500 or so for a set, the Goodyear AltiMAX RT43's seem like good all around tires, even in winter. I'm comparing them to the Michelin Defenders we put on our Legacy last year (which after 13,000 miles seem decent, but weren't really great in the snow last year). A lot of reviews for the Defenders were saying people were only getting 40K miles from a tire rated for $90K, which hardly seems worth paying $650 for a set (it was $550 for the set 14" tires on our Legacy). One local tire place is quoting $472 a set installed for the AltiMAX and I'll have to check with the other place we deal with in town. For me, that seems like a good price for a tire I might expect to get 50K miles out of (they are rate dfor 75,000 miles).
It's time to replace the worn, noisy leaking tires that came on our 2005 Impreza Outback Sport when we bought it last winter. I'm looking for a reasonably priced tire with decent traction (but not a dedicated winter tire- not really justifiable here in VA). The car is a daily driver/ grocery getter, so not looking for a performance oriented tire- just something for general use. What are some tires that you've had good luck with on your Subie?
Found the answer- the CEL triggered the ECU to shut down traction control system and Cruise Control. Question was- what caused the CEL? I'm hoping it was the gas cap (I filled up last night). I made sure it was tight an did a "poor man's" ECU reset (pulled the negative battery cable). CEL is cleared and stayed off for the 40 mile trip home. Need to get me a code scanner- this one seem sot have some good feature (and good feedback for the price): http://www.amazon.com/dp/B003IOKPLO/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=26KO1LKD4DVWE&coliid=I180WOW7NENNHG
I put a new slave cylinder on tonight. I had a lot of trouble bleeding it, but ended up disconnecting the clutch pedal to let the rod that connects to the pedal link come alll the way back, so the bleeder vent is exposed. That did the trick as I was able to bleed the slave and get some pedal back. It still seemed to disengage the clutch only when all the way to floor, but then while the clutch pedal linkage was disconnected I realized the pedal adjustment was way off. I adjusted it so it is engaging the clutch more and now I have all sorts of travel and the clutch released about 1/3 the way off the floor. The pedal does seem to sit a bit high up but it works smoothly and the shifts are smooth.I also don't hear the squeak from the bells housing when I push the clutch (maybe it was the slave, or maybe it will come back). I'll drive it on the 80 mile round trip top work tomorrow and see how it does.
