George1943
Everything posted by George1943
1986 Justy 4WD -- Engine ID Help?
George1943 replied to Rooster47's topic in Old Gen.: 80's GL/DL/XT/Loyales...
From what I can see, it looks like either an EA71 or EA81 4 cylinder. -
	The splines in one of my front hubs was stripped out when that happened to me a few years ago.
1983 Subaru GL 4wd - Clutch replacement issues
George1943 replied to Calibud916's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree with silverhelme. I'm thinking the grinding noise you heard with the old clutch was the axle slipping in one of the front hubs. Maybe you didn't need a new clutch after all. Try putting it in gear ( two wheel drive ) and with the clutch pedal out, have someone look at the front axles to see if one of them is just spinning in the hub. If it's not moving anyway, you could just get out and check for yourself if you don't have someone to check for you. -
EA71 Piston Orientation
George1943 replied to Otterby's topic in Historic Subaru Forum: 50's thru 70's
77 1.6 valve adjustment
George1943 replied to Thegreasemonkey's topic in Historic Subaru Forum: 50's thru 70's
With the engine cold- 1 reply
- 1
	I switched to a Weber and haven't regretted it for a second. Lots of other people have done that too. The only vacuum hoses that I use that I can think of are 1 to the AC control, 1 off of the carb to the distributor vacuum advance , and 1 to the power brake booster. All the others are capped off. I still use the PCV valve but I think some people cap that off too. Hope this helps.
Sway bar end link bushings
George1943 replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
These stabilizer bushings are available at Rock Auto, Oreilly's, and probably other places as well. -
84 brat EA81 a/c low side port?
George1943 replied to StallonePanerai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The high side is the line that goes to the condenser in front of the radiator.The low is the one that comes from inside the car. The low side hose is bigger than the high side hose. The sight glass eye is on the high side. -
New member Ea-81 hydro lifters
George1943 replied to Darrel504's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In the 'Shop Talk' section, search for 'Adjust hydraulic valve lifter'. There's a write up on how to adjust them. -
	Easy. Just look in the same forum where you posted your question. On Sept. 25, Eric Anderson has a link to a 1982 Subaru FSM. He spent a lot of time scanning it and posted it for all to share. I, for one, really appreciate the trouble he went to to do that for us. . .
	I don't have any of the parts that you need but I have some info that you may not be aware of. I used the door handle from a '80 sedan on the tailgate of my '81 Brat. Perfect fit. I'm telling you this so you won't be tempted to pay a premium price for a handle thinking that only a tailgate handle will work on a tailgate.
No power to the ignition??
George1943 replied to soobie87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've had a problem like that before and the battery posts just needed cleaning. Simple, easy fix. Worth a try. -
EA71 head gasket??
George1943 replied to MICHAEL1977's topic in Historic Subaru Forum: 50's thru 70's
My first thought is your intake manifold gasket(s) is leaking water into the intake part of the manifold. -
Ignition Coil ground???
George1943 replied to Dave Soslau's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you sure there's not a condenser on that wire? -
Correct break in for new rings and bearings?
George1943 replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No fire on cylinders 2 and 4
George1943 replied to Jmpjose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you had the engine apart changing the head gaskets,etc., did you stuff a rag or something in the intake ports to keep unwanted things out while the engine was apart? If so, maybe you forgot to take it out of that head when you put it all back together. I've heard of that happening to other people before, but never to me (I wish). -
	Here is a picture of my AC belt arrangement. It's on a 1982 Brat DL. I would assume yours to be the same.
Big valves or little valves?
George1943 replied to George1943's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you john in KY for those measurements. I agree with jono, not enough difference to get too excited about. -
Thanks to all for your responses. Does anyone know the actual measurements of the small and large valves?
