Everything posted by Skip
You could also check at the dropping resistors on the pass side fender well (see below)? This devise has battery voltage in and four wires out, one to each injector. The injectors are fed battery voltage through the dropping resistors and the ground for them is provided by the ECU as G points out. If the resistor for #1 injector was toast (never seen it happen) only #1 would be effected.
And no response to this post since 12/25/2007 over two months???!! I don't know if we want this type of character doing business on the USMB?? Caveat Emptor -- comes to mind.
Kewl. Then wire it to the relay output contact going to the starter and hang it below the dash. The ignition switch "sweet spot" GD mentions is why I ask for this. I have added this relay to a half dozen Subes and never had a failure - except for the "sweet spot" problem.
Troubleshooting Ea81 fuel pump
Skip replied to slideshow86's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Jess, if you want to understand this system take a few minutes and read this post. http://www.ultimatesubaru.org/forum/showthread.php?t=82917 GD's post #10 tells a lot about this device. -
pull the panel under the streering coluum look for a pink colored connector that feeds the ignition switch. It probably has a melted contact in it that will be quite obvious. Show us the wiring diagram you used for this new relay, please. Do you own a test light that could be wired to the relay contact that goes to the starter?
Everything you wanted to know about our Weber Carbs
Skip replied to Skip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well done Sir Greenley!! I did not have to do that but I thank you very much for your guidance. Emailing it is very difficult as it is so large. Thanks agian, I hope it works that way for all who want a copy. -
You are most welcome Tcat? I hope it helps answer your situation, and showed the helpful folk where your problem is. Here's gidonya mate.
Nice shots, good info. I want to say thanks to Jared, for having the consideration to resize them so they fit on the screen.
What will....
Skip replied to gbianchi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
blown hoses can be fixed with duct tape but.... where's the water to refill the system. This vehicle must get some serious fuel economy. What happens when the fuel pump gives it up? -
I like the method AE points out We old timers call them "hoof picks" - man that is old time!! Another use for a hoof pick is removing stuborn hoses. Stick the point in and wiggle it around the pipe (shoot some ju ju of your choice in if you like) See photo at right. The hose can then be rotated and pulled right off. I have a longer "snouted" one that works better but.... guess there is something to having too much stuff ....grrrrrrrrrrr I hate when I can't find a tool.
sorry, I hope you were right clicking. If you want a copy, please email me and I'll send it that way. -
Sir Guru, please deal with this!! Or offer refunds to those tired of asking.
Weber fixed...Now timing issues????85 Brat
okay weld what you must if you read a bit on these acceleration vibration problems I believe you will see a large contingent saying the DOJs (inner CVs to some) is the primary cause of this. Sorry, I tried, I'll leave it to you and GD now 'Ave a gidday mate -
Okay guys try this link http://pdftown.com/PDF-Weber-Installation-Instruction-for-Suzuki-Samurai.html After getting to the page you should see Under this picture you should see Download l Mirror Right click on either and select "Save as" Please let me know if this helps. -
Brian, Sir Sorry, but you did ask for suggestions the dogbone is one bolt and nut It could be preventing the movement you need. Maybe if you showed a picture of your install (top mounted AWIC?) it would help prevent these nebulous replies (suggestions). I said loosen not remove the tranny mount bolts/nuts I have two of these turbo wagons, and have not seen all these problems. (never had an engine out of one yet though)
I happen to have an EA82T sitting "topless" on one of my benches. I took a close look at where Tcat says the problem is. I saw NO separation like you mention in any cyl. Is this the proper area of concern you speak of?
EA82 problem need some advice help
Skip replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Amen to that!! Being the impact type helps sometimes also. Stuby wrenchs come in handy also. But not for that nut!! -
The site Pdftown.com is loaded with kewl .pdf files I clicked automotive (top of page) then "Subaru" Just have to see the list to believe http://pdftown.com/Subaru-PDF-eBook-Category.html This deserves mention in a separte post. My recco is purchase a cheap laser printer (~ 70 bucks) then you can cheaply print your own copy of whatever. -
Sorry Joe, I just tried it again worked fine you must go to the page with the picture I posted. under the picture right click on "Download" select "save link target as" It should open a page that allows you to save "Weber Manual .pdf" as a .pdf file. Hope this helps When trying, did you see the picture I posted?? -
You are correct guys it's a bit corn-fusing Go to the linked site PdfTown.com Then you must click on the title " Weber Installation Instruction for Suzuki Samurai" When the page opens under this picture You will see "Download l Mirror" Right click either and use "save link target as" Pick the folder you want to store it in when asked click "save" I've tried to link it differently to no avail the above method will work. Reminder: Pictures, blow up parts layouts tuning tips, jet sizes 28 pages whole nine yards of concrete info. Please let me know if you made it happen or are still having problems.
