subidude04 Posted October 10, 2009 Share Posted October 10, 2009 Found a MINT '89 gl-10 ea82t, guy said head gasket was blown. tore engine apart, found tiny cracks in between the valve seats. is this terribly bad? should i replace them? And if so, where can i find refurb heads? Quote Link to comment Share on other sites More sharing options...
john in KY Posted October 10, 2009 Share Posted October 10, 2009 Cracks between the valves are very common and are to be expected/ignored. Subaru refers to them as "bridging cracks". But do look for a crack up in the port runner. A crack there and time for another head. The heads used on the XT and any model with a turbo are the same. Engine has to be the MPFI type. Quote Link to comment Share on other sites More sharing options...
subidude04 Posted October 12, 2009 Author Share Posted October 12, 2009 does the XT have to be turbo? if not, i found one i can pull the heads from Quote Link to comment Share on other sites More sharing options...
john in KY Posted October 12, 2009 Share Posted October 12, 2009 Just check the back of the passenger-side head. The holes used to mount the turbo should be there, just not threaded. Also the provision for the turbo oil-return line should be there but will need drilled. Quote Link to comment Share on other sites More sharing options...
subidude04 Posted October 12, 2009 Author Share Posted October 12, 2009 thank you! thank you! that is exactly the answer i was looking for. So im going to go ahead and order up the new ea82 heads and drill them and tap to make them work on my wagon! thank you! Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 13, 2009 Share Posted October 13, 2009 Keep in mind, that while Subaru was building EA82 Turbos, they phased through 3 generation of EA82T head designs. If you are looking to replace your heads, you might do good by looking through the junkyards and see if you can find a new(er) EA82T Motor with Gen3 heads on it. Read through here to help identify the differences between Gen1, Gen2 & Gen3 heads: http://www.ultimatesubaru.org/forum/showthread.php?t=48560 -Brian Quote Link to comment Share on other sites More sharing options...
subidude04 Posted October 13, 2009 Author Share Posted October 13, 2009 I found some remanufactured, decked, vaccuum tested heads for 125 a piece. They are mpfi and gen2 I believe. I jumped all over it lol Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 13, 2009 Share Posted October 13, 2009 It's been said that the Gen 3 heads were only availible after the production of EA82T's stopped as replacement parts. GD Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 13, 2009 Share Posted October 13, 2009 I found my Gen3 heads on a 1989 GL10 Sedan when I was rebuilding my RX motor. Quote Link to comment Share on other sites More sharing options...
