Delta Cam roll call
Delta Cam
The vendor section seems pretty slow these days. Let's try to get some attention in here. How many people are running Delta Cams and which engine?
1. Qman, EA81 (2X), ER27 (2X), EJ25 (2X) plus several Chevrolet cams through the years.
PROUD to say Im running a Delta Cam torque-grind cam in my BRAT's EA81! :headbang:
As soon as I can gather another complete EA81... the HP grind will be next :banana:
How do you like the torque grind vs stock? I am assuming it is similar to a chevy V8 tow truck grind...
I am thinking about my EA71 rebuild.
Thanks.
OK, One more question, what RPM do you guys run when you do a HP grind??? 7 or 8k? Will the regrinds hold up under the pressure of racing valve springs?
-Daniel
Edited by danrenfroe2016
more!
  • 3 months later...
So I would assume that you can do cams for any Subaru engine? Even a 2.5 turbo?
That is true. We have several grinds available.
Yes they can. I just spoke with them a minute ago about my EJ25D heads, and they also do work on wrx's and sti's.
Nice to talk with you today!
  • 2 weeks later...
  • 1 year later...
  • 2 weeks later...
