Guest Bob Alexander Posted June 17, 2003 Share Posted June 17, 2003 I just bought a 2003 outback wagon. I'm looking for a way to improve ground clearance when off-roading. An adjustable system that can be controlled from inside the vehicle (like an Audi allroad) would be perfect. If not available, I'm looking for a source for a lift kit. Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted June 17, 2003 Share Posted June 17, 2003 You're probably asking for a little much with the in car height adjustment. Check out www.isrperformance.com they have scorpion lift kits. Quote Link to comment Share on other sites More sharing options...
Guest soilmapper Posted June 18, 2003 Share Posted June 18, 2003 I don't think you will find any air-based suspension systems, but something might be out there. A much cheaper alternative would be the springs and lift kit from ISR. I just put the springs on my 97 OB wagon (64 k). I would definitely recommend them for this car. I think the car should have come with them from the factory. They have not only improved ground clearence, but also (along with new struts) tightened up the handling. Much less body roll with bikes and gear on the roof. Hope this helps. Kent Quote Link to comment Share on other sites More sharing options...
