chadwick35/04 Posted November 15, 2009 Share Posted November 15, 2009 I have a 2004 subaru legacy and for some reason I am not to sure where the pcv valve is? Can anyone help me on this? Quote Link to comment Share on other sites More sharing options...
valvestem Posted November 15, 2009 Share Posted November 15, 2009 Here's a pic I found to help you locate the PCV valve... Quote Link to comment Share on other sites More sharing options...
ferret Posted November 16, 2009 Share Posted November 16, 2009 The above picture is for the 2001 and earlier. Starting in 2002, the PCV valve was moved to the OTHER end of that hose down in the engine block rear. On the 2002 and newer, that picture is just an orifice where the upper end of the PCV valve attached to the throttle body. Follow that hose down and you will find yours. Also note, it IS a different valve and part number from the one that was mounted on the throttle body as shown. Quote Link to comment Share on other sites More sharing options...
valvestem Posted November 16, 2009 Share Posted November 16, 2009 (edited) Sorry about the wrong answer, at least the OP should be able to find the PCV now with your instructions and the pic. Edited November 16, 2009 by valvestem Quote Link to comment Share on other sites More sharing options...
