mjcee Posted November 30, 2009 Share Posted November 30, 2009 (edited) Hey everyone, My soob sat at a park and ride for 6 days and when I got back in to drive away, a weird thing started happening. A weird grinding/jingling noise is coming from the shifter, especially pronounced when I shift. The noise goes away when accelerating and comes back when decelerating. Seems like something is dragging at first. Then I realize that I can move the shifter up and down (vertically) about 2 inches like a VW, but not). Hmm... something definitely broke/came loose in the the shifter. I did some searching on the forums and it sounds like it could be bushings or a spring (or both)?? I am going to pull off the console cover and shifter boot but I'm not really familiar make the parts underneath. Anybody have any suggestions on what the prob. might be and what to look for? Is there a reason this would have happened so suddenly? It's an EA82T with a 5 speed manual trans. Thanks in advance! Edited November 30, 2009 by mjcee Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 30, 2009 Share Posted November 30, 2009 There's a pivot and associated bushing at the very bottom of the shifter - easier to access from the under the car. Just pull the shelf down and replace the bushing, etc. GD Quote Link to comment Share on other sites More sharing options...
rlpete Posted September 21, 2013 Share Posted September 21, 2013 I have been reading about loose shifter most likely being result of worn bushings and to replace the whole set. Is this a dealer item? I have not had any luck finding the shifter bushings aftermarket. Any suggestions would be appreciated. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted September 21, 2013 Share Posted September 21, 2013 Yea call the dealer. I rebuilt the shifter in my former coupe with all new bushings from Subaru and the GD shifter fix (bolt instead of roll pins) and it firmed it up a ton. You could have also broken the rubber mount that attaches the shifter to the trans tunnel. You wont know until you get under there and see. Btw is this 2wd or 4wd? The setup is slightly different between the two but generally speaking the same idea. Quote Link to comment Share on other sites More sharing options...
rlpete Posted September 22, 2013 Share Posted September 22, 2013 Mine is the 2wd. I have it jacked up right now swapping out the front wheel bearings, can you tell me what and where to check? Quote Link to comment Share on other sites More sharing options...
rlpete Posted September 28, 2013 Share Posted September 28, 2013 I got a chance to get under the car while I had someone that could move the shifter for me. All of the bushing look tight and it seems all of the looseness is inside the transmission. To verify this I grabbed the shaft coming out of the transmission with pliers and held it and there was no looseness in the shifter. Could this be the rubber shifter mount in the transmission tunnel? Any help would be appreciated this is my first Subaru so I am still learning how they work. If this is not the shifter mount does anyone know what may be going on inside the tranny? btw it is an 86 XT DL 5 speed 2wd. Thanks, Quote Link to comment Share on other sites More sharing options...
Gloyale Posted September 29, 2013 Share Posted September 29, 2013 (edited) My bet is the rubber mount at the BACK of the shifter mechanism has come apart, allowing the shifter to rub on the driveline. Especially pronoucned when the trans lifts at the back slightly like under decel or hard reversing. The 2wds are also known for wallowing out the rollpin hole that holds the shifter "u-joint" yoke to the shaft. Similar to the older 4spds. Seach General Disorders thread on the 4-spd sloppy shifter fix. Edited September 29, 2013 by Gloyale Quote Link to comment Share on other sites More sharing options...
