p2098 Post Catalyst Fuel Trim System Too Lean Bank 2
so this is a U5 car...it prob. has the 3 piece intake manifold and the triangle shaped exhaust ports in the heads....hmmm...as mentioned check for intake/vacuum leaks also check for exhaust leaks..If you have the means I would also check the IAT/MAF/CTS sensors...all vital engine sensors that could throw numerous codes..
  • 9 years later...
  • 5 weeks later...
