BG on 31s....
Numbchux
saw this at Sno*Drift, and talked to the owner/builder quite a bit. It was finished the day before the event, and driven across the lower peninsula of MI to the event without problems. Cheers to them!
the recipe:
'96 LGT wagon
take the stock EJ25D, and add STi pistons and rods
then add a TD04 and associated intake/exhaust/IC parts
bolt it to the stock LGT 4.444 4EAT
add some 6" subframe blocks
some 6" strut top extensions
and some plates to extend the strut-knuckle connection about 2"
some 1.5" wheel spacers
and some 31x10.5" tires
as seen Jalopnik:
http://jalopnik.com/5462681/my-dads-subaru-wagon-can-beat-up-your-dads-everything
we took a ton of pictures, which should be up very soon.
i tried the same lift idea on the lower strut mounts on my outback wagon last night, i can do it, and even get the camber correct, but i would either need wheel spacers, or i would have to use some sort of fwd gm wheel, We tried one and it fit. With the Subie wheel, the tire rubbed the strut pretty bad.
