soobydaddy Posted February 12, 2004 Share Posted February 12, 2004 So sincer I am pulling the engine to do the head gskt on my 87 GL10(since lots of steem is coming from the THROTTLE BODY:D )what are the best mods(in a poor mans price range)To do at the same time?I love this car and want to give her some(what I can get)"power and speed"but keep the off road ability for some Florida fun. Thanx:cool: Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 12, 2004 Share Posted February 12, 2004 invest in a valve removal tool and a dremel(with snake atatcment), and PORT THE HEADS instant turbo response, better bottom end, better high rpm if you had a carb block laying around, go with that. cut out the airbox, install a cherry bomb what we did with the RX, costs us no more than the gasket set, and a hand ful of dremel bits http://www.warpthree.com/milesfox/87rx/rxbuild/rxbuild001.html look far enough and you will see the ported heads Quote Link to comment Share on other sites More sharing options...
soobydaddy Posted February 16, 2004 Author Share Posted February 16, 2004 Should I do the timing chains at the same time(sounds like a good idea to me but...)? Do I need a lift to get it(engine)out or could 2 of us lift it out? what about a lift kit but with the same tires 195 70r 13? Waht are a good set for on and off roading? Thanx fox. oh ya how bout a turbo rehab...do I need? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 16, 2004 Share Posted February 16, 2004 its a good idea to replace the timing belts unless you just replaced them. If you do go with Genuine Subaru timing belts or else you'll end up replacing them in a few thousand miles. As for lifting the engine out, if you have about 3 or 4 strong friends, its possible but it would be a lot easier and faster to do it with a engine lift. Aslo, if you plan on lifting it, why would you wanna go with the same size tires? I'd get a set of 14" Pug steels and put some offroad tires on them OR get a set of 6-lug Chevy rims and redrill them to fit the Subaru lug pattern. As for the turbo, there's no really cheap way to get around this. You can either find one in a j/y with low miles on it, find one on ebay or you can rebuild it yourself but the rebuild kit is 150 bucks alone....... Quote Link to comment Share on other sites More sharing options...
Meeky Moose Posted February 16, 2004 Share Posted February 16, 2004 it is possible to lift an ea82T out of the car with just 2 people.. done this several times now.. easiest way is to take all the accesories off (alternator, ac compressor, etc..) and the intake manifold.. this sheds 75lbs or so.. Quote Link to comment Share on other sites More sharing options...
Subi81 Posted February 16, 2004 Share Posted February 16, 2004 I was able to lift the engine in and out with three people, two lifting and one supervizing but we did it minus alt, and ac. Just make sure you get a really strong board or better yet metal pipe. Ours broke on the way back into the engine bay, Good luck!! Quote Link to comment Share on other sites More sharing options...
calebz Posted February 16, 2004 Share Posted February 16, 2004 Board? Pipe? We just reach in , grab a head and pull out the lump...... Have done it with 2 people.. Easier with a third for supervision though.. especially when I'm the supervisor:D Quote Link to comment Share on other sites More sharing options...
