Durania Posted June 5, 2011 Author Share Posted June 5, 2011 (edited) Yeah, I couldn't believe the dang thing fit either. Installed a 03 WRX seat last night that I got a smoking good deal on. It does sit about an inch higher but that was expected from where I had them in my RS. I do need to re-tap a seat hole that decided to strip on removal of stock bolt. Edited June 5, 2011 by Durania Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 5, 2011 Share Posted June 5, 2011 lol for me when i took out the seat the bolt behind the seat the welded nut under the car came off. I wanted to put wrx seats in mine but heh Quote Link to comment Share on other sites More sharing options...
Durania Posted June 5, 2012 Author Share Posted June 5, 2012 Have not done an update in a long time. Traded with a guy and got JDM wagon tails My WRX headunit finally died, sourced another one from another friend and put it back in. Put new rear rotors on Sunday. The ones on it were the factory ones. Made in Japan and sent over here to Indiana. They were shot. Got the new ones on and the car did not want to move, acting like the parking brake was on. My father in law and I took them back off and got a wire brush and scraped a TON of rust off the 6 o'clock position of the assembly that contains the parking brake mechanism. We got it to roll again but it makes some rubbing noise. No brakes are dragging and is not affecting driveability. Just makes noise like a bad wheel bearing when making turns. Figured it would eventually wear down. We are taking it to Florida on Saturday. Looking forward to the drive. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 5, 2012 Share Posted June 5, 2012 F... I would give my kidneys for the JDM tails.. when I totaled my 95 Legacy I did not have the effen deep sockets to get the tails off and I had to leave them on the car.. They are a rip off to buy.. and those i got for a decent deal because the guy was in NY.. I've been looking for some since I'm painting the car in 2 months and I want to do my custom LED tail lights. Quote Link to comment Share on other sites More sharing options...
Durania Posted June 5, 2012 Author Share Posted June 5, 2012 Oh man, I love the tails on this thing. Did wonders for the car. I traded dude the factory rear sway bar from my STi plus the stockers. We traded in the walmart parking lot. It was a PITA. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 5, 2012 Share Posted June 5, 2012 Yeah they are a lot better then the USDM lights for sure I like how the turn signals and reverse lights all come with Fresnel lenses. between me needing another set of wheels and tires I might not be able to get them until next month providing I can find someone that's selling Quote Link to comment Share on other sites More sharing options...
bratman18 Posted June 5, 2012 Share Posted June 5, 2012 Looks great. I wouldn't mind having a set on mine. I think I will get JDM projector headlights first though. You should move this to the members rides section!! Quote Link to comment Share on other sites More sharing options...
Durania Posted June 6, 2012 Author Share Posted June 6, 2012 I sent mick a pm for it to get moved. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 6, 2012 Share Posted June 6, 2012 Looks great. I wouldn't mind having a set on mine. I think I will get JDM projector headlights first though. You should move this to the members rides section!! I've got JDm projectors I've had them on my table for like 3 months now.. I put in some FX-R projectors.. very tight fit which required a lot of cutting.. I'm running some Rebel LED's for turn signals.. I'm using a relay on it so I get my turn/parking light blink when the headlights are on. I'm about 502 Lm at full brightness, Not sure if I ever showed the pictures here but here is a youtube video of me manually powering it. WE have a member's ride section? Quote Link to comment Share on other sites More sharing options...
Durania Posted June 6, 2012 Author Share Posted June 6, 2012 Yeah man http://www.ultimatesubaru.org/forum/forumdisplay.php?f=81 Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 6, 2012 Share Posted June 6, 2012 Hmm never knew that. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 6, 2012 Share Posted June 6, 2012 Looks great. I wouldn't mind having a set on mine. I think I will get JDM projector headlights first though. You should move this to the members rides section!! Finally a break in the weather so I tested it today Quote Link to comment Share on other sites More sharing options...
Durania Posted June 6, 2012 Author Share Posted June 6, 2012 I like those yellow fogs. Did you modify the JDM headlights so they don't shine into the oncoming traffic? Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 6, 2012 Share Posted June 6, 2012 I like those yellow fogs. Did you modify the JDM headlights so they don't shine into the oncoming traffic? Thanks, the yellow fogs are stock but with yellow film I got on ebay.. been on for about a year now.. it really helps with the contrast at night. The JDM headlights I took out the only thing I kept was the bracket to mount the projector in.. I'm running these projectors in the car but the older 2.0 version http://www.theretrofitsource.com/product_info.php?products_id=101 it's a tad tight in the housing with very limited up and down movement.. once I get the ballasts I can check how high/low I need to aim I really miss the tail lights however lol To do the rear end it's going to cost me around $160 or so to convert to LED's at least the two reverse lamps and turn signals only... I'm about to build a LED array for the 3rd brake light Quote Link to comment Share on other sites More sharing options...
Durania Posted June 11, 2012 Author Share Posted June 11, 2012 Drove this thing to Florida on Saturday. Got around 27 mpg loaded completely down and AC on. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 11, 2012 Share Posted June 11, 2012 Drove this thing to Florida on Saturday. Got around 27 mpg loaded completely down and AC on. that's not bad at all sometimes I think it's better to drive with the AC instead of driving with the window open Quote Link to comment Share on other sites More sharing options...
987687 Posted June 11, 2012 Share Posted June 11, 2012 that's not bad at all sometimes I think it's better to drive with the AC instead of driving with the window open On the highway, it probably is. I run AC when it's hot because driving over about 50 with a window open drives me nutts. Quote Link to comment Share on other sites More sharing options...
Durania Posted June 14, 2012 Author Share Posted June 14, 2012 The only time I run with the AC on is when I have my little boy or passengers with me. Chalk it up to many years in a non-AC hatch and BRAT. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted June 15, 2012 Share Posted June 15, 2012 The only time I run with the AC on is when I have my little boy or passengers with me. Chalk it up to many years in a non-AC hatch and BRAT. The only car I ever had with working a/c was my Outback... until I crossed a flooded road and completely screwed the ac pump. Many years of EA82s made that an easy fact to come to terms with. Now I'm in an '84 DL and guess what... no ac. Oh well at least I have those awesomely huge openings thanks to the lack of a B-pillar I totally appreciate the fact that car was made that way. Miss the Outback though... You're lucky, that's a great family vacation wagon!!! Quote Link to comment Share on other sites More sharing options...
Durania Posted June 19, 2012 Author Share Posted June 19, 2012 Well, she survived the round trip to the Florida gulf coast and back. 2 hours from home it threw a check engine light getting on the interstate. I have been driving the STi so I have not had the time to drive it to town to get the code pulled. Was hoping I could do it with my Cobb AP but it didn't work. It did work on that 02 WRX I was working on a few months ago. Here she is about to make the long journey home. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 19, 2012 Share Posted June 19, 2012 Those are not stock tires right? sidewall looks smaller.. I can't wait to get off those size 70 sidewalls.. car rolls onto the sidewall when turning hard Quote Link to comment Share on other sites More sharing options...
Durania Posted June 20, 2012 Author Share Posted June 20, 2012 I think so. Dude put those on there three months before I bought the car in June 2010. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 20, 2012 Share Posted June 20, 2012 heh the part of my car that rusted out is where that stupid part is near the rear door right where the rocker panel and the door meet.. I never understood that.. I have to fix it up before I paint the car. Quote Link to comment Share on other sites More sharing options...
Durania Posted June 20, 2012 Author Share Posted June 20, 2012 Don't let the picture give this cars paint job too much credit. It's not that shiny. Quote Link to comment Share on other sites More sharing options...
