ValuedCustomer Posted December 23, 2010 Share Posted December 23, 2010 hey just wondeing what you think this is ? get a pulsation on the steering wheel and barly on the brake peddle when breaking moderatly. do you think this is just the break roters being unballanced? when i pull this apart to see what the roters look like what should i look for? Quote Link to comment Share on other sites More sharing options...
BEECHBM69 Posted December 23, 2010 Share Posted December 23, 2010 hey just wondeing what you think this is ? get a pulsation on the steering wheel and barly on the brake peddle when breaking moderatly. do you think this is just the break roters being unballanced? when i pull this apart to see what the roters look like what should i look for? It sounds like classic symptoms of a warped rotor. I don't know you would be able to see it with the naked eye, but you can certainly tell if they are scorched or gouged. Dan Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 23, 2010 Share Posted December 23, 2010 +1 on warped rotors. They are cheap to replace. Quote Link to comment Share on other sites More sharing options...
KristjanJohann Posted December 23, 2010 Share Posted December 23, 2010 Def the rotors. Change them out and the pads also... and if you can feel it to the steering wheel, it's def the front rotors Quote Link to comment Share on other sites More sharing options...
nipper Posted December 24, 2010 Share Posted December 24, 2010 Also check the sliders on the calipers to see if that caused the rotor warp. Quote Link to comment Share on other sites More sharing options...
ValuedCustomer Posted December 25, 2010 Author Share Posted December 25, 2010 what are the sliders? and how could they warp the rotors? Quote Link to comment Share on other sites More sharing options...
nipper Posted December 25, 2010 Share Posted December 25, 2010 what are the sliders? and how could they warp the rotors? Those are the pins that the calipers slide on. The calipers are basically giant clamps. Rotors warp either because of hard spots in mfg, sudden cooling after being EXTREEMLY hot (like a dragging caliper), or a dragging caliper. You may not notice a dragging caliper when you change the pads. Always clean and lubricate the sliders at every pad change. Use brake grease, it comes with the better pads. Dragging caliper can heat the rotor too much. Quote Link to comment Share on other sites More sharing options...
HATCHY Posted December 27, 2010 Share Posted December 27, 2010 Hows the rubber? Because I just went through this. I was hunting down snowtires in my buddys subaru parts graveyard.. I had discovered snow tires that had like 90 percent tread, and those thing were light braking wobble, over 40 wobble over 50 death roll. come to find out they were retreds, Discount tire two brand new ones problem solved Quote Link to comment Share on other sites More sharing options...
