TheLoyale Posted June 27, 2014 Author Share Posted June 27, 2014 Hmm, whats this? Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted June 27, 2014 Share Posted June 27, 2014 where did you get that snorkel !!?? i have been looking for one that matches the angle of the hood and windsheild Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 28, 2014 Author Share Posted June 28, 2014 (edited) 90-97 Mitsubishi Montero/Pajero NK/NH http://www.ebay.com/itm/351059163830?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 This doesn't match perfect, but a heat gun and some Sand will take care of reshaping it. El_Freddo from AUS did this first and this is where I got the idea. Edited June 28, 2014 by TheLoyale 1 Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 28, 2014 Author Share Posted June 28, 2014 Snorkel fitted! Just need to heat it up and bent it to follow the A-pillar better. Used a 3" Hole Saw, perfect fit! used a Step drill on the stud holes and adjusted as needed. Just need to make a custom fit connector for the air box outlet. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted June 28, 2014 Share Posted June 28, 2014 Will you be removing it to fill/empty it with sand? If so you should totally make me a template to line it up in the right spot on the fender! Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 28, 2014 Author Share Posted June 28, 2014 I am thinking about leaving it on the car to reform the upper part of it closer to the A-pillar, but I am wondering if the Heatgun will take its toll on the Windshield/Seal? If I did take it off the form it, I would indeed need to make something for reference as to how far to bend it. Any ideas...? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted June 28, 2014 Share Posted June 28, 2014 I'd do it on the car for sure. But if you don't use sand, it might not bend as smooth and might buckle the snorkel. So you'd have to take it off to add and remove the sand. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 29, 2014 Author Share Posted June 29, 2014 Oh, yeah I'll have to clean all the sand out lol. I don't have the fender bolted down, I still have to finish the floor pan/rocker area before I can finally bolt it down for good. I should really take a photo of the driver side rear strut tower, I think it'll be "OMFG" moment for everyone on the west coast Quote Link to comment Share on other sites More sharing options...
TomRhere Posted June 29, 2014 Share Posted June 29, 2014 I should've gotten pics of what the parts Wagon looked like when I stripped it. It would make the rust holes on yours look good. Work so far is looking good. I so need a welder here... Liking the snorkel. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 29, 2014 Share Posted June 29, 2014 The Snorkel idea is Awesome, I like the SafariWagon. ...I would indeed need to make something for reference as to how far to bend it. Any ideas...? Why not only take the proper angle Measurements? Kind Regards. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 29, 2014 Author Share Posted June 29, 2014 Tom, I think you did post pictures of how bad it was? I do remember the rear tube being cracked in half. Here is my main headache right now I did finish the passenger side footwell today! Happy with the results. As for the Snorkel, I was thinking about taking measurements, but I found that it may be easier to bend it while its on the vehicle so I can see right where it needs to be. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted June 30, 2014 Share Posted June 30, 2014 Your wheel well looks good compared to what was under the side trim of that Wagon. Why the strut didn't rip out is beyond me. They had filled the whole side of it with foam, totally borked the seatbelt retractor. Floor repair looks good from the pic. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 30, 2014 Share Posted June 30, 2014 Looking awesome there Thomas, and it's going to be even better once that snorkel is fitted properly!Then we'll be L series bothers in more ways than one - you have one of my ideas on your L, I've got one of your parts on mine (the coupe grille!) ^ That's Nachaluva Matt's Foz where I got the idea of which unit to use after comparing his before it went on his foz I'm not happy with my bracket on the A pillar - since my snorkel was hand-me-down second hand unit it didn't come with the bracket, this what I came up with using what I had. Not really neat and I'm still refining it - I got a rivnut tool and inserts to hold the bracket on now, previously I was using a couple of screws (highly NOT recommended!) While I had the sand in mine I took the time to do some bending of the snorkel's intake for a bit more of a natural angle - just makes it look like it's really meant to be there - I'll have to dig up an image of this being done - I used some rachet straps on some choice angles to get a better look, still could have pushed it further... but it's all good! I'm looking forward to the finished product! I bet you can't wait!CheersBennie Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted July 2, 2014 Share Posted July 2, 2014 Can't wait to see it back together, looking good Tom. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted July 6, 2014 Author Share Posted July 6, 2014 Pulled away all the tower skin, cleaned up the main strut support and reinforced it with some 1/8" Round bar. Next up, remaking the shell skin and rewelding the latching point for the seat backs. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted July 8, 2014 Author Share Posted July 8, 2014 The Snorkel is 100% finished! I am super keen on the fit! 3 Quote Link to comment Share on other sites More sharing options...
Vegablade Posted July 8, 2014 Share Posted July 8, 2014 Looks really good! 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 9, 2014 Share Posted July 9, 2014 Yes, Looks Awesome! Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted July 14, 2014 Author Share Posted July 14, 2014 More progress on the rust repair aspect. Finally this is for the most part, complete. I dreaded this part of the build ever since discovering it, as it has very many different bends/twists and also needs to be very strong as its a key structural piece. Now it is finished! Stay tuned for more updates! 1 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted July 14, 2014 Share Posted July 14, 2014 It looks like it is probably even stronger than it originally was. Nice Job! Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted July 14, 2014 Author Share Posted July 14, 2014 I think it might be. I even reinforced the actual strut mount, also having full welds Vs. Spot welds is going to increase strength. I kinda wish both sides were equal, but I am not about to cut into the other side again lol... Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 14, 2014 Share Posted July 14, 2014 Looks Awesome Thomas, now is Time to Prepare those Areas for Painting against Rust. What is your Plan on that subject? Keep the Good Job and the Updates coming! Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted July 14, 2014 Share Posted July 14, 2014 Awesome work mate! I think I need to get a welder! Also - how'd you end up doing the inner guard plumbing for the snorkel?Cheers Bennie Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted July 14, 2014 Author Share Posted July 14, 2014 JesZek, Once I finish the welding in the area I am planning on brushing on Rust-Oleum Truck bed liner for the entire floor (Like I did on the Skiwagon) then I will be laying down FatMat sound deadening on the entire floor plus inner body panels. I have already used DynaMat for the roof and also reglued the support slats for the roof, No more banging hopefully! As for the outside, I am planning on painted the Floor/Rockers/Wheel Wells with the same thing, then spraying Paintable, hard undercoating to protect it even more. Bennie, I am stilling thinking about the plumbing for the Snorkel. Looking at it, I may have to notch out and reweld the frame piece that runs behind the fender, it looks like it may be just too tight. Perhaps I brought back the snorkel a little further than you did which is why you didn't have any issue. 2 Quote Link to comment Share on other sites More sharing options...
dannycisneros Posted July 16, 2014 Share Posted July 16, 2014 Hey what size is your roof rack I'm trying to get the same one for my 88 subaru gl wagon! I've also seen pictures of your car on a different website I don't remember which one but how big did you have the tires when you had it at stock height? Quote Link to comment Share on other sites More sharing options...
