Help me hack my ignition switch.
It sounds like the ignition *lock* has a problem, not the *switch*.
Remove the lock, take it to a locksmith, and have it rebuilt and new keys made. (in the meantime - turn the switch with a screwdriver)
Replace the switch with an OEM one from the dealer when you get the lock back - about $25.
i meant lock , i just call it a switch. im not quite sure how to take it apart. are there any how-to's on here ? i tried searching but it kept saying no results.
You still need a key switch or several toggle switches to turn on and off the accesory and ignition power circuits - besides just the push-button for the starter. And you *should* install a relay to run the starter as well as relays for the accesory and ignition circuits if you are going to do that. Replacing the key switch with a push-button and seperate power circuit switches is not something I would reccomened unless you are well versed in electrical work. That's not a small or particularly simple task.
^ Plus on top of what GD has said you also need to work out a way to safely disengage the steering lock - you don't want that to engage halfway around a corner!!
Cheers
Bennie
