Kostamojen Posted August 16, 2011 Share Posted August 16, 2011 I've been trying to get some assistance with this in the Historical section to no avail, so I'll try here... I have a Bosch internal voltage regulator alternator I'm putting in my FF-1. I cut the wires for the voltage regulator which ended up leaving two wires, one black/white and one white red. But I'm not sure which ones go where into the plug on the Bosch alternator which has a yellow and green wire: Does anyone know which I should plug into which? Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted August 21, 2011 Author Share Posted August 21, 2011 Does anyone at least have a wiring diagram for a internally regulated alternator car that I can look at? Quote Link to comment Share on other sites More sharing options...
bigjimd Posted August 21, 2011 Share Posted August 21, 2011 You sure thats a Bosch? Sure looks like it says Hitachi on the back. I tried to find you something but had no luck. Whats the model # of that unit? I think one wire goes to a wire thats hot in run at the key and the other goes to the light on the dash. Big red one to the battery and I think there is a male spade connector somewhere that goes to ground. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted August 22, 2011 Author Share Posted August 22, 2011 (edited) Ya, you are right, it is a Hitachi. Came in a Bosch box though Sorry about the confusion. Bosch AL241X is the part number that was on the alternator before I took the sticker off. Trying to figure out which hitachi it should be... It is a 60 amp. http://www.partsgeek.com/mmparts/alternator/subaru/standard.html Edited August 22, 2011 by Kostamojen Quote Link to comment Share on other sites More sharing options...
bigjimd Posted August 22, 2011 Share Posted August 22, 2011 Check this out see if any of it makes sense to you. http://datsun1200.com/modules/mediawiki/index.php?title=Hitachi_LR_Alternator Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted August 22, 2011 Author Share Posted August 22, 2011 From that article, the b/w wire should go to the S (yellow) and the r/w wire should go to the L, correct? One thing I'm confused about, is if the BAT wire has to connect with the other two wires at any point. before the fuse box. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted August 22, 2011 Author Share Posted August 22, 2011 This is close to what my wiring harness was originally like. Note the white/red and black/white wires going from the voltage regulator to the rest of the car: Quote Link to comment Share on other sites More sharing options...
donnieru Posted August 23, 2011 Share Posted August 23, 2011 Hi. That alternator looks like the same one that I have on my 91 Loyale SPFi ea-82. From looking at mine it would be the thicker wire(your yellow) would be BW and the thinner wire (your green) would be WR. Great job on your FF1 btw. Can't wait to see the final on it. Been a faithful reader of your thread since the beginning. Don Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted August 23, 2011 Author Share Posted August 23, 2011 Hi. That alternator looks like the same one that I have on my 91 Loyale SPFi ea-82. From looking at mine it would be the thicker wire(your yellow) would be BW and the thinner wire (your green) would be WR. Great job on your FF1 btw. Can't wait to see the final on it. Been a faithful reader of your thread since the beginning. Don I'm fairly certain you are correct. I think my one concern right now is whether the white wire (BAT) needs to cross over to the Yellow or Green (BW or WR) at any point... Quote Link to comment Share on other sites More sharing options...
bigjimd Posted August 24, 2011 Share Posted August 24, 2011 I think y'all have it right. No I don't think it ties to either of those 2 directly. Take the Heavy White wire to the battery then a pigtail from the battery terminal to the fuse box at terminal #2 . I would put a circuit breaker in that line. Your schematic shows a 70amp load at terminal 2 so a 70 amp cb should be good. I'm not real sure of that though, I don't think it would ever see that at one time maybe a 60 or even 50 would be better. Make sure you use a proper size wire there. Might be a good idea to let someone else chime in on that thought. If you do, put it close to the battery end. And I agree I have just about read your whole journey, really sweet project. Takes a lot of determination to see such a long project through. A lot of people would have tossed in their hat or passed it on by now.You are just about there now. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted August 24, 2011 Author Share Posted August 24, 2011 I think I have a circuit breaker I can use. I think I do have it pretty close to being correct. I'm going to double check everything tomorrow and add that ground to the alternator. Still no idea why the wipers went dead... Quote Link to comment Share on other sites More sharing options...
bigjimd Posted August 24, 2011 Share Posted August 24, 2011 (edited) Without that jumper it looks like you should have all kindsa stuff not working. Wiper, washer, horn, lights, etc. To bad my father in law moved to Yreka. He is a wiz at this kind of stuff and could have hooked you right up. They Left Roseville a couple of years ago. Edited August 24, 2011 by bigjimd Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 25, 2011 Share Posted August 25, 2011 (edited) After going over the previous posts here it looks to me you guys are on the right track. The only thing I noticed that should be done is a fuse needs to be placed in the main alternator output lead that ties to the battery in case the main lead gets shorted at the alternator somehow. The fuse may need to be around 80 amps or slightly more than the rated output of the alternator. The 'S' lead of the alternator is the battery sense lead which needs to tie to the battery through a fairly small fuse. It normally uses the b/w wire like you stated. It senses the battery voltage so the internal regulator will know how much current to produce to keep the battery charged up. The 'L' lead is the lamp lead that normally ties to the w/r wire which is connected in series with the battery warning light and then to switched ignition power (the ignition switch). The lead supplies power to the exciter field of the alternator which gets the alternator action started. Edited August 25, 2011 by Cougar Quote Link to comment Share on other sites More sharing options...
