Guest kecksnext Posted August 11, 2003 Share Posted August 11, 2003 Has anyone made a tool for compressing the brake caliper piston? Some pics would help a lot. when I had my first Roo years ago I made a little piece with 2 pins but was a 2 person job, not very efficient now days. BTW who came up with and what benefit is there to having a threaded piston? Quote Link to comment Share on other sites More sharing options...
Guest Tom63050 Posted August 12, 2003 Share Posted August 12, 2003 I don't think the piston is actually threaded, but for some reason I've heard you screw it in clockwise. You can do it with a pair of pliers. There is a six-sided little cube thingy you can get at an auto parts store that you fit onto the end of a 3/8" drive socket extension, that makes the job a little easier, but it's not absolutely necessary. Quote Link to comment Share on other sites More sharing options...
Guest ShawnW Posted August 12, 2003 Share Posted August 12, 2003 I did. I made it by taking a piece of thick steel pipe that is round and cutting it so that there are 2 notches across from each other. Quote Link to comment Share on other sites More sharing options...
Guest kecksnext Posted August 12, 2003 Share Posted August 12, 2003 For some reason I remember having to turn the piston while compressing it at the same time. Is that right or will it compress simply by turning the piston? Thanks for the quick responses. Quote Link to comment Share on other sites More sharing options...
Guest OH Noah Posted August 12, 2003 Share Posted August 12, 2003 Many brake calipers that incorporate a parking brake use a threaded piston. I'm not really sure how it works, but it has to do with the parking brake self-adjusting. You can buy (or borrow from Autozone) a disc brake kit that has many different sizes of discs with pins in them for the purpose of compressing threaded caliper pistons like ours. The little cube tool works too, but it's kinda clunky. Quote Link to comment Share on other sites More sharing options...
Guest calebz Posted August 12, 2003 Share Posted August 12, 2003 For ten bucks, the cube is worth it. Beats the hell out of banging up your knuckles trying to do it with needle nosed pliers.. easier on the piston too Quote Link to comment Share on other sites More sharing options...
Guest ShawnW Posted August 12, 2003 Share Posted August 12, 2003 With the pipe you hole the caliper in your left hand and press the notched pipe in while you twist it right. Quote Link to comment Share on other sites More sharing options...
Guest baccaruda Posted August 12, 2003 Share Posted August 12, 2003 lots of the nice tool sets on ebay for cheep search.ebay.com/search/se...liper+tool Quote Link to comment Share on other sites More sharing options...
Guest OH Noah Posted August 12, 2003 Share Posted August 12, 2003 Those 11 piece sets are the ones you can borrow from Autozone. Quote Link to comment Share on other sites More sharing options...
Guest SubaruJunkie Posted August 12, 2003 Share Posted August 12, 2003 I made a tool for this job. I took an old socket, something in the standard size that I would never use. I made sure the diameter was big enough to cover both notches in the cylinder, and then i used my dremel to cut away at the socket leaving only 2 sections sticking out. Now I just use a socket wrench, and my special socket to reset the calipers. It can be a pain in the rump roast to reseat them, but if you undo the bleeder valve alittle it helps releave pressure. I have pictures somewhere, if I can find them i'll post them. -Brian Quote Link to comment Share on other sites More sharing options...
Guest Sweet82 Posted August 12, 2003 Share Posted August 12, 2003 For as often as you have to do it, I just use Channel Lock pliers. :x Every few years fighting with that #$% piston is not that big of deal. If I had a herd of Subarus, I'd make a tool. I do it so infrequently, I have a hard enough time just remembering how:rolleyes: :x :x Spin it and be done with it! For what its worth, Glenn 82 Hatch, now with partial Rhino frame:evil: 01 Forester, with Subaru frame:lol: Quote Link to comment Share on other sites More sharing options...
Guest SubaruJunkie Posted August 12, 2003 Share Posted August 12, 2003 Its not easy to spin, and plyers can hurt your knuckles or risk damging your caliper or the boot that protects it. I have 2 Subaru's, but the 1st thing I do to any Subaru I buy is the brakes. This simple little socket might not be used much, but when i need it, its great to have. -Brian Quote Link to comment Share on other sites More sharing options...
Guest subyaddict Posted August 12, 2003 Share Posted August 12, 2003 The piston turns in nice and easy if you rebuild it. I did my driver's side and now it is VERY easy. No knuckle smashing involved. I'm going to do the right side next. It's not very hard, but it takes more than two hands, or the special tool for copacting the conical washers on the back. That's also where the threaded pin the goes from the parking brake lever (the one on the caliper) to the back of the piston. Other than that it's very easy and very much worth the effort. It definitely improved the pedal feel as well. My 2 cents Nathan 1983 gl wagon 4wd d/r 5sp, R-LSD, R-discs, 180deg stat,10 deg advance,87 octane no knock at full throttle uphill on a hot day,Really top speed approx.95mph next up SPFI and Kumho R700 Gravel tires Quote Link to comment Share on other sites More sharing options...
Guest moosens Posted August 12, 2003 Share Posted August 12, 2003 I've been told by Subaru Master Techs that if you don't turn them in you're ruining them. I've been using duckbilled pliers but the last few jobs busted my balls so I'm going for the tool...sometime. Quote Link to comment Share on other sites More sharing options...
Guest choinka Posted August 13, 2003 Share Posted August 13, 2003 I just use the tool for removing discs of a hand grinder. Most people have one, and I never have a hassle using it. It's already got the two teeth which will fit if you have a right size. Richard Quote Link to comment Share on other sites More sharing options...
