Loyale 2.7 Turbo Posted November 29, 2011 Share Posted November 29, 2011 (edited) Where could I Find a Cooler temp Thermoswitch for my EA82 BumbleBeast?The Stock EA82 one is designed to start the electric Fan at 203º F while the EA82 Turbo one is Designed to Kick on at 200º F. I am Looking for something even Cooler to swap there, Because I am Removing the Fixed Pulley Driven Fan and installing another Electric fan instead, as you can read ~► Here. So, does anybody know of a Cooler thermoswitch and its part Number or Make/model of the car?Kind Regards. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
nipper Posted November 29, 2011 Share Posted November 29, 2011 WHy not just get an aftermarket fan switch kit. They usually have an adjustable thermostat on them. Go to ebay and search "adjustable fan switch" Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 29, 2011 Author Share Posted November 29, 2011 (edited) OK, I'll do that search...I was hoping that there could be a Direct Bolt-on Replacement.Our caribbean Hot Climates makes me to be Afraid about not having the Pulley Driven Fan and the stock electric fan is designed to start when the Temp gauge are Above the Middle as an "Auxiliary" fan because the main fan is the permanent one, moved by the Waterpump & Belts... Also the Electric fan kicks on, whenever the A/C is on.Kind Regards. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 29, 2011 Author Share Posted November 29, 2011 (edited) Maybe I Can Refine my Question: is there any other (Subaru or non-Subaru) Thermoswitch that is designed to Kick on at lower temperatures than the Stock one, that Fits on my Subie? ... I Need the Year / Model \ Part Number. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
zukiru Posted November 29, 2011 Share Posted November 29, 2011 I've been looking too just for what willi fit from the junkyard, not for a colder one. The older cars switch has one pole/terminal (won't work) The loyale and ej switch looks similar but has a pigtail with a different connector. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 29, 2011 Author Share Posted November 29, 2011 (edited) Yes, the Stock one comes with a Twin wires' pigtail connector... (my BumbleBeast came from California, USA) ...the replacement I Obtained at the Subaru Dealer (Long years ago), is identical to the Stock one, but has the Twin spades connector built in because it was for the LADM (Latin American Domestic Market) Specs; the only difference is the Connector itself, the temperatures are the same: Both Kicks on at 203º F and has the same thread & Size.Kind Regards. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
zukiru Posted November 29, 2011 Share Posted November 29, 2011 Both my us spec xts have your replacement style. I think 85-88 use that style. What year is the bumble beast. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 29, 2011 Author Share Posted November 29, 2011 (edited) ... What year is the bumble beast. 1985 I can search for a Picture of the Old Pigtailed Thermoswitch.... Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
zukiru Posted November 30, 2011 Share Posted November 30, 2011 I believe you. Just have the other style on my 86 and 88 xt Maybe california models got the pigtail style. Keep in mind though you car needs to get to operating temp. Running cold can decrease fuel mileage Quote Link to comment Share on other sites More sharing options...
opus Posted November 30, 2011 Share Posted November 30, 2011 They want like $70 for one of them. I need one too but I aint paying that for it! Quote Link to comment Share on other sites More sharing options...
El Presidente Posted November 30, 2011 Share Posted November 30, 2011 If you can't find something to work, my hayden 3647 fan controller costs $20-25 USD at O'rielly's and can be set anywhere between 160-210 degrees F.. It can be used on any fan, comes prewired for an optional auxiliary fan, A/C override and creates less resistance in the circuit than a stock switch. It also uses a probe you push through the radiator fins so you don't have to monkey around with the stock thermo switch bung. I all took me about 25-30 mins to install and dial in. My rig warms up fast because theres no fan turning when cold, but never gets above the middle of the gauge. If you go this route you could wire a light to the old OEM switch to one of the fans as a backup in case your nearing an overheat and/or wire a warning light to it to let you know sometings wrong I didn't realize you asked me for pics of my setup in your other post. I can get you some pics if you still want. Josh Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 30, 2011 Author Share Posted November 30, 2011 (edited) Yes, Pics Please! ... I'll like to see that Thermoswitch, also I want to know if you Wired it to the Stock Wiring...Kind Regards. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 1, 2011 Author Share Posted December 1, 2011 (edited) I believe you.Just have the other style on my 86 and 88 xtMaybe california models got the pigtail style... Well, I found it! This is the Old original pigtailed Thermoswitch: This is the New one that I Had as Replacement, long years ago: This Pigtailed Thermoswitch has the Part Number: 83052GA041 and it has its Temperature stamped in Celcius Degrees, as we use in Latin-America: 92º C equals to 198º F The other Style: Has the Part Number: 83052GA040 and it has its Temperature stamped in Fahrenheit Degrees: 203º F equals to 95º C Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 2, 2011 Author Share Posted December 2, 2011 (edited) So, on the EA82 engines I Found that... the Pigtailed connector Thermoswitch, it designed to Kick on at 198º F the twin spades connector Thermoswitch Kicks on at 203º F the Turbo (EA82T) Thermoswitch Kicks on at 200º F ...Does anybody Know if there are any Lower temperature Thermoswitch I Can place on my Subie's Radiator? Kind Regards. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 4, 2011 Author Share Posted December 4, 2011 Seems like I'm the First one investigating for a Cooler temp Thermo Switch. So, the Thread measurements for the Original Subaru Thermo Switch, are: Yes, 16 X 1.5 Pitch... interesting, since Many Many cars came with that Same Measurement for Thermo Switches, according to the Beck Arrnley Thermoswitch Listings. Beck Arnley Thermo Switches are Made in italy, of Good Quality Brass, I Found the Replacement Right for the EA82 engine: Quote Link to comment Share on other sites More sharing options...
87.5ea82txt Posted January 16, 2012 Share Posted January 16, 2012 So what did you end up using to control your fans? Quote Link to comment Share on other sites More sharing options...
opus Posted January 16, 2012 Share Posted January 16, 2012 I just put the one above your post in the other day. Works fine, $23 on eBay. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 17, 2012 Author Share Posted January 17, 2012 (edited) I just put the one above your post in the other day. Works fine, $23 on eBay. Yes that works fine for the Stock EA82 that also has a permanent mechanical Fan, because it is how factory intended to use the electric fan: As Auxiliar, so It comes ON at 203º F (95º C) and that is Hotter than I should run permanently my BumbleBeast without the mechanical fan... Remember: I wanted a "Cooler" temp thermoswitch, because I'm gettin' Rid of the mechanical Fan. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 17, 2012 Author Share Posted January 17, 2012 So what did you end up using to control your fans? Yes, I Already found the Solution last December... I was just waiting a Whole Month of test drive my BumbleBeast prior to post here what I did, in order to give just the Proper advice. So, I'll post here all the information Soon. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 7, 2012 Author Share Posted February 7, 2012 (edited) SOLVED!And the Results are Awesome! So, I Wrote a Complete Writeup about the Solution, which included other Solutions for the Complete Cooling System.You can Read it, ~► Here Kind Regards. ► Edited to fix the Web Link, due to the New USMB's System. Edited February 6, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 7, 2012 Author Share Posted February 7, 2012 (edited) I answered my own question. This is a Resume part from the Writeup I Posted. (Link on the Previous Post) ____________________________________________________ ...if now the Coolin' System will Depends only on Electric Fans, They'll need to Start earlier than the Risky 203º F (95º C) for Sure, due to the Fact that they will be no More "Auxiliary" Fan, nor a permanent "Mechanical" fan... just Twin Electric Fans. So I Found that the Subaru's Thermo switch has the Followin' measurements: M 16 X 1.5 Pitch And Doing my Research, I found that some Hyundais came with Same measurements on their Thermo Switches, and certain models came with Cooler Temperature Ranges than Subarus. This is the Original Subaru EA82 Thermoswitch and its Part Number: 83052GA041 There are Aftermarket ones too: But since in my Own Humble Opinion, They're Too Hot to be "Safe" for the head gaskets on long term use on the EA82 without the Mechanical fan; I Found This one: It Belongs to a Hyundai Elantra, this is the Part Number chart: The part number could end in zero or one, because it has variants for different Hyundai models; no problem; but I Kindly suggest you to use the part number from the Hyundai part's Box, in the Photo. Here you can See Both Thermo Switches Compared Side by Side, and their Temperature Ranges in fahrenheit and Centigrades: This is the New, Hyundai Thermo Switch: Testing it to fit onto the Subaru's Radiator: Already plugged in: Same Measurements at All. Edited February 7, 2014 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 7, 2012 Author Share Posted February 7, 2012 It has over a Month of Hard Driving and Works Awesome! When my BumbleBeast reaches the Operating Temperature and the Twin Fans starts, they work for only a Minute and the engine needs Ten Minutes to reach the Opening temperature again, when I tested the car on a Closed Garage. I Hope this Solution can Help. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 6, 2014 Author Share Posted February 6, 2014 Two years has passed since my last report, so let's post a New one. The Cooler temps Thermoswitch on my "BumbleBeast" has been working Flawlessly since I installed it, in December 2011. Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
