Caboobaroo Posted January 20, 2012 Share Posted January 20, 2012 I've been toying with the idea of doing a walk through on the EJ25s for awhile and was wondering if there is any want for something like that? Would it be a good addition to the USRM? Since I do at least one a week at work, I was thinking about documenting them with pictures and post up a full write up on them, along with parts that are used. Jus a thought..... Quote Link to comment Share on other sites More sharing options...
tractor pole Posted January 20, 2012 Share Posted January 20, 2012 that would be great! I have been looking for a Forester with bad head gaskets to fix and make a winter car for my wife. Quote Link to comment Share on other sites More sharing options...
mattocs Posted January 21, 2012 Share Posted January 21, 2012 I'd read it. I have been thinking about getting an Outback that needed head gaskets and either replacing them or dropping my EJ22 in, so I've been reading everything on head gaskets that I can find. If you do a tutorial, include pictures! Quote Link to comment Share on other sites More sharing options...
davebugs Posted January 21, 2012 Share Posted January 21, 2012 I believe the best I'd found was the "skipnospam" link back in the day. Combined with always getting the latest HG torque seguence from the dealer (actually the whole HG replacement procedure) just incase it changed. I'm unaware of one for the 2.2 swap so that would be nice. Quote Link to comment Share on other sites More sharing options...
vasy Posted January 21, 2012 Share Posted January 21, 2012 I've been toying with the idea of doing a walk through on the EJ25s for awhile and was wondering if there is any want for something like that? Would it be a good addition to the USRM? Since I do at least one a week at work, I was thinking about documenting them with pictures and post up a full write up on them, along with parts that are used. Jus a thought..... I'd really appreciate it if you can gather the pics/procedures and post it here. I have a 96 2.5. It still has the factory HGs, sooner or later I'll need to replace them. Once you post it, I'll copy/paste it to my hard drive and save it. Quote Link to comment Share on other sites More sharing options...
vasy Posted January 14, 2013 Share Posted January 14, 2013 Is there a write-up somewhere? Quote Link to comment Share on other sites More sharing options...
987687 Posted January 15, 2013 Share Posted January 15, 2013 A nice writeup with torque specs and procedures would be cool. Tips and tricks. Things like knowing that you should torque the water pump bolts twice, not compressing the tensioner too fast, how to hang the timing belt, etc would be good tips for beginners. Also that 2.5 SOHC engines have a timing belt tooth count +3 on both sides of what the FSM says, that really boggled me the first time I did a 2.5 sohc. Quote Link to comment Share on other sites More sharing options...
Turbone Posted January 15, 2013 Share Posted January 15, 2013 I had some communication with Russ tonight about this, we are going to try and get it done. Its going to take the better part of a day to do, so it needs to be set up in advance at where he works. Quote Link to comment Share on other sites More sharing options...
Downbound Posted January 15, 2013 Share Posted January 15, 2013 Here is the link to skips hg and clutch replacement... http://home.comcast.net/~skipnospam/Head_gasket_replacement.html Quote Link to comment Share on other sites More sharing options...
ivans imports Posted January 15, 2013 Share Posted January 15, 2013 i do two 2.5 headgasket jobs a week never ending for the rest of my life at least i will always have work. I could show some pics of the head surfacer in action is neat to see when i surface the blocks how bad they realy are. A'm working on jiging it up to surface a assembled short block strait off the car will try on the 2.5d engine i do on thursday Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 15, 2013 Share Posted January 15, 2013 Here is the link to skips hg and clutch replacement... http://home.comcast.net/~skipnospam/Head_gasket_replacement.html I looked at that before I did mine it helped but in the end I went by the FSM it will be two years April since I did my HG. Quote Link to comment Share on other sites More sharing options...
