Digital Torque Wrench - Special
blmw
Brown Line Metalworks is a manufacturer of Digital Torque Wrenches. We are offering members of this forum the following: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: ultimate
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until March 1st, and is only for the lower 48 states.
We are located in Chicago, IL. Phone is: 312-884-7644. Email: info@brownlinemetalworks.com
What is the COO / country of origin for this product? Just curious, didn't see it on the web site. Thanks.
The ratchet and the steel components of the wrench are manufactured in Taiwan, and the electronics and assembly are done in Malaysia. Our repair / calibration facility is located in Chicago in case anything ever needs to be done to the wrench.
BLMW
google search found this site showing USA as COO:
http://fortyone.co.nz/parts/show/2645/Brownline/Digital%20Torque%20Wrench.html
amazon has them for same price with free shipping.
The one on Amazon that is the same price is without the case. Amazon sells the case version for $119.
In regards to the Country of Origin, the link that you post has the incorrect information (the correct is above).
BLMW
Sell one that does angles? I own a SnapOn Techwrench with the Angle function but it was extremely expensive and way out of budget for anybody that isn't a full service shop. $724 last I checked for one. Awesome, worth it to me, but not for a couple head gasket jobs like most people would encounter.
We do not currently sell one, but it is something we are working on - should be available later this year.
BLMW
