brycarp Posted June 2, 2012 Share Posted June 2, 2012 Just wondering whether anyone has a "try this first" for a 96 5MT Legacy that "buzzes instead of cranks", maybe about 1 in 4 times when the key is turned to start. It usually cranks on the second try. Sometimes I think that I push harder on the clutch pedal against the floor and maybe that helps, but it could be unrelated and the second try would have worked anyway. It sure sounds like the buzz comes from "up under the dash" rather than from the starter on the other side of the firewall, but I haven't nailed down the location of the sound yet by having a "volunteer" try cranking while I listen under the hood. With an intermittent problem, you ususally can't get it to happen when the volunteer is present. :-\ Thanks! Bryan Quote Link to comment Share on other sites More sharing options...
Wayback Posted June 3, 2012 Share Posted June 3, 2012 Clutch switch is out of adjustment or failing, or starter interlock relay is failing. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted June 3, 2012 Share Posted June 3, 2012 that sounds like the solenoid is going out, also check the connections on the starter. Quote Link to comment Share on other sites More sharing options...
brycarp Posted June 3, 2012 Author Share Posted June 3, 2012 Thanks for the tips! I can tell I have some "metering" to do. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 3, 2012 Share Posted June 3, 2012 Please post what you find. Mine does the same thing occasionally, about one in 50 starts, but it always works the second turn. I figured it has to be some relay under the dash, but with the infrequency of it I always forget about it until it happens again. Quote Link to comment Share on other sites More sharing options...
jarl Posted June 3, 2012 Share Posted June 3, 2012 I usually blame that kind of behavior to a low voltage... maybe a bad ground? Quote Link to comment Share on other sites More sharing options...
