Moosen Posted June 4, 2012 Share Posted June 4, 2012 So i finally have been adjusting my choke. I closed it up and it starts actually now. and on a dime. But was restricting when driving. So i opened it more and it started and drove pretty well, some chugs every once in awhile. So i just drove home (7min drive) and checked the choke plates when i got home and they werent all the way open. engine temp said warm. So shouldn't they be vertical and all the way open? So I opened the choke till the were vertical, but then I get a problem where when WOT from Idle the car bogs, and or dies? So what do I do about this? Quote Link to comment Share on other sites More sharing options...
spazomatic Posted June 4, 2012 Share Posted June 4, 2012 stock? or weber? Quote Link to comment Share on other sites More sharing options...
Moosen Posted June 4, 2012 Author Share Posted June 4, 2012 stock? or weber? weber Quote Link to comment Share on other sites More sharing options...
Moosen Posted June 5, 2012 Author Share Posted June 5, 2012 bump? Quote Link to comment Share on other sites More sharing options...
Moosen Posted June 6, 2012 Author Share Posted June 6, 2012 hello? Quote Link to comment Share on other sites More sharing options...
TomRhere Posted June 6, 2012 Share Posted June 6, 2012 Choke should be fully open on a warm engine. It really should be full open before engine reaches operating temp. I can't give you an exact temp or time on that though. Disty timing could have an effect on your bog. Play around some with the base timing. Stock is 8*BTDC, but you can run with more advance with the Weber. I've had the same Weber setup on 3 different engines, all of which liked a different timing setting. Does the vacuum advance unit on your disty work properly? Accelerator pump could cause a bog also. May have to adjust it's linkage. Quote Link to comment Share on other sites More sharing options...
Moosen Posted June 10, 2012 Author Share Posted June 10, 2012 Are you saying I should advance my disty even more to rid the bog? I am already running around 12 or 13 degrees. I am just tired of this tuning! Urgh..... Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 11, 2012 Share Posted June 11, 2012 I Run my Weberized BumbleBeast EA82 @ 20º without Problems, So I Kindly Suggest you to Try advancing the Time a Li'l More and let us Know if that Help. Kind Regards. Quote Link to comment Share on other sites More sharing options...
