1-3-2-4 Posted February 1, 2014 Author Share Posted February 1, 2014 ^man I would love to have a outback that clean! I have a huge rust issue on the passenger side rear door area where that stupid black plastic part is.. I hope I can shape some metal to wield on that area. Anyways I'm going to start building this MSD coil kit, I just need to run to home depot to get some longer bolts, need to still order valve cover gaskets and everything so far is going good. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 2, 2014 Share Posted February 2, 2014 Thanks, that outback had no rust anywhere which was awesome, what is the advantage of the msd coil kit? Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 4, 2014 Author Share Posted February 4, 2014 They say a bigger spark 36Kv vs the 20 or so with the Subaru. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 5, 2014 Share Posted February 5, 2014 Thats interesting, I wonder if they make one for the EJ22? I'll have to look into that. Thanks! Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 5, 2014 Author Share Posted February 5, 2014 Car wont start now. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 5, 2014 Share Posted February 5, 2014 Won't start with the new coil? If you put the OE one back on will it start up? Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 5, 2014 Author Share Posted February 5, 2014 Turns out it was the starter.. I replaced the contacts but not the plunger about two years ago. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 6, 2014 Share Posted February 6, 2014 Nice troubleshooting! Whats next for the wagon? Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 6, 2014 Author Share Posted February 6, 2014 Most likely JDM taillights and modding them for LED's I need for the spring to come so I can replace the hatch, hood and body repair. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 7, 2014 Author Share Posted February 7, 2014 Ordered this today http://www.ebay.com/itm/281127989860?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I really needed just the plunger but I will just replace everything again, it's super easy to get to the starter anyways. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 8, 2014 Author Share Posted February 8, 2014 too tired today to do the timing, still trying to check where that coolant leak is.. I can only think it's a hose or i forgot to put a hose clamp on near where the IAC is, it only leaks when the system is full, Changed the oil yesterday. Any tips on getting to the knock sensor? LOL last time I had a very hard time getting the bolt onto the sensor.. I remember dropping it and having a hard time trying to fish it out, the way the 25D's intake manifold is makes it harder.. I was thinking maybe some glue on the end of the bolt head so I can at least thread the bolt in. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 9, 2014 Share Posted February 9, 2014 What helped me do the knock sensor is taping the edge of the bolt with electrical tape into the socket so it would hold it, then as soon as its tightened you can easily pull the socket up. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 9, 2014 Author Share Posted February 9, 2014 Doh forgot about that! yeah that would work! Also I'm going to try and get as much teardown as I can of the old block.. it's been riding around in my wagon for almost 3 weeks now. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 9, 2014 Share Posted February 9, 2014 Haha that's hilarious! Sounds like a typical subaru guy, it's rather terrifying if you were to wreck and that thing came flying at or around your face! Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 9, 2014 Author Share Posted February 9, 2014 Haha that's hilarious! Sounds like a typical subaru guy, it's rather terrifying if you were to wreck and that thing came flying at or around your face! lol funny you should say that I had to come to a hard stop the other day and that was my first thought.. just glad my tool bag was zipped up at the time. I'm going to try using the bar to get the wrist pins out for the pistons Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 9, 2014 Author Share Posted February 9, 2014 LOL you can tell I'm a newbie at this.. I did not know the pins for the pistons were so visible after you take the circlips off.. I expected them to look a bit different.. lol Anyways I took some video of that #2 piston on the Ej25d block, it must be at least 5 mm of play on the crankshaft.. took the oil pan off and it looked like glitter I will keep Piston #1 as a keepsake Anyone know what size the bolts are that are where the water jackets are? I thought it would be 14 mm 12 point but it's smaller.. maybe 10? Also redid the timing on my hybrid motor and holy crap does it pick up after 3K.. It feels better in that range than the Ej25d IMHO, it spins up faster it just feels so good! I found my coolant leak which did not take too long to find as soon as I started the car up I guess the screw band was not tight enough so it would leak right on the block and the headers and made a nice smoke cloud. Videos in a few since I need to head out. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 10, 2014 Author Share Posted February 10, 2014 (edited) Video of the crankshaft and the crazy play! So it seems low oil so far killed it, wont really know until it gets split but all the others had no play. Edited February 10, 2014 by 1-3-2-4 Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 12, 2014 Author Share Posted February 12, 2014 Almost forgot about the starter kit coming in the mail today, I will get around to it tomorrow. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 14, 2014 Share Posted February 14, 2014 Well? Today is yesterdays tomorrow, did you finish up that starter? I had full intentions of installing a hitch on my car after work today, yet I arrived and had not the slightest amount of motivation. Perhaps tomorrow. But only if this baby stays in thy wife a little longer. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 14, 2014 Author Share Posted February 14, 2014 Got hit with another 7 inches of snow Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 14, 2014 Share Posted February 14, 2014 Damn, where do you live Mike? I forget if I asked before. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 14, 2014 Author Share Posted February 14, 2014 Connecticut we have at least 24 inches total so far. . I have to do it today because I stalled on a hill and was unable to start it again.. because yesterday was so light in traffic I just parked in the middle of a heavy road hit the starter and that was it Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 14, 2014 Author Share Posted February 14, 2014 Found a clean enough spot and took the starter out and replaced everything, now just time to put it back in. Quote Link to comment Share on other sites More sharing options...
Scooner Posted February 15, 2014 Share Posted February 15, 2014 I love the good ol starter smack! Hopefully you got that thing in and it was successful. I always hated getting to that bottom nut. Im gonna hook up a trailer wiring harness tomorrow, should be about 60 which is nice. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 16, 2014 Author Share Posted February 16, 2014 ha 60 is nice! Here is the starter repair I took the pistons out of the Ej25, turns out I had a long drill bit.. like 15 inches long and it was 1/4" pins came out real easy. Now I had to order online a 12mm 12 pt thin wall socket because no stores here had one that was thin enough to get to the bolts where the water jackets are. Quote Link to comment Share on other sites More sharing options...
