DavieGravy Posted July 16, 2012 Share Posted July 16, 2012 My car was fine 3 or 4 days ago and today I can't get it to start. I turns over just fine but refuses to run. I can get it to run for a few seconds by spraying carb cleaner into the intake, but it quickly dies. Does anyone know what the problem might be? I've checked all the hoses and they appear fine. The car will not run even with the air box removed. I also checked the fuel pump connector in the back and cleaned the contacts with contact cleaner, but nothing. It's almost as if the fuel pump went out completely. It was at the mechanics getting a "speed sensor" and duty C replacement. Is it possible they messed something up? Also, while it was at the mechanics, it was hit from behind by a tractor trailer. Could the impact have caused damage to the fuel pump or anything else? Thanks Quote Link to comment Share on other sites More sharing options...
heartless Posted July 16, 2012 Share Posted July 16, 2012 car needs 3 things to run - fuel, air & spark. since you can get it to fire with a shot of starting fluid, my guess is it isnt getting fuel, and that is what you should be checking first. make sure there is power to the fuel puimp then see if it is actually pumping. and as far as the truck hitting it, how much physical damage was done? regardless, doubtful it would actually damage the fuel pump - purely coincidence IMHO. Quote Link to comment Share on other sites More sharing options...
DavieGravy Posted July 17, 2012 Author Share Posted July 17, 2012 There was very little damage from the accident. How can I check to see if it's pumping? Thanks Quote Link to comment Share on other sites More sharing options...
illanrob Posted July 17, 2012 Share Posted July 17, 2012 Looks like you drove the car from the shop, then drove it for a few days and now it will not start. Could be a loose connector: air mass sensor, crank sensor,....these control spark. You should be able to verify if the fuel pump is working, disconnect the ignition coil connector, to inhibit a spark, disconnect the fuel line at the fuel filter just before the injector, then turn the key and look for fuel. You could verify a spark, remove a sparkplug, connect plug cable, let it make contact with chassis ground, turn the key and look for a spark on the plug. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted July 17, 2012 Share Posted July 17, 2012 I can be hard to reach but if you want to bring it by my shop let me know. Link below to contact info. Fuel pump is certainly a possibility, and very common on this era of Subaru. Are you saying it won't run now that the mechanics have worked on it or it took 3 days after they did to have trouble? Quote Link to comment Share on other sites More sharing options...
DavieGravy Posted July 18, 2012 Author Share Posted July 18, 2012 It ran for 3 or 4 days or so after getting it back. Thanks for the offer, but I think I'll take a stab at this myself. Quote Link to comment Share on other sites More sharing options...
DavieGravy Posted July 18, 2012 Author Share Posted July 18, 2012 I tested the voltage at the connector. With the key on: 6 volts at the yellow and 12 volts at the green next to the black. The rest were dead With the key off: All dead. Is it possible the impact knocked something lose like the fuel pump modulator or ground wire? Since it's in the rear of the trunk where the car got hit this might be plausible. Or is it more likely the relay went bad? Thanks Quote Link to comment Share on other sites More sharing options...
DavieGravy Posted July 19, 2012 Author Share Posted July 19, 2012 The starter relay (located under the dash by steering column) clicks when the ignition is turned on, so I assume it must be the fuel pump. I guess without knowing what the voltage should be at the connector and what wires should be live or dead, it'll be an $85 gamble. I'll post back my results after I replace my fuel pump. Quote Link to comment Share on other sites More sharing options...
Brian FORD Posted July 20, 2020 Share Posted July 20, 2020 We've been waiting 8 years for those results! I have those same problems. 1 Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 20, 2020 Share Posted July 20, 2020 11 hours ago, Brian FORD said: We've been waiting 8 years for those results! I have those same problems. I applaud you for searching, seriously. But, best to start your own thread with your own details, then add onto another (especially a long-dead one). 1 Quote Link to comment Share on other sites More sharing options...
