1-3-2-4 Posted October 17, 2012 Share Posted October 17, 2012 I was just curious was the going rate for getting a replacement window? someone had tints on this one before but pulled it off which pulled off the lines, I did paint half the lines but I just thought about it, if I put tints on those lines are really going to show up. Quote Link to comment Share on other sites More sharing options...
J A Blazer Posted October 17, 2012 Share Posted October 17, 2012 I raised this very question with my glass installer while he was doing the windshield on my 2000 OBW because my rear window is scratched. He said the rear window is quite expensive ($600 or so) and can only be obtained from the dealer; no aftermarket suppliers. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 17, 2012 Author Share Posted October 17, 2012 ouch.. figured Quote Link to comment Share on other sites More sharing options...
ocei77 Posted October 17, 2012 Share Posted October 17, 2012 Junkyard. Whole hatch. Still dear but cheaper. Try car-part.com and see what they give for price. Should be cheaper locally O. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 17, 2012 Share Posted October 17, 2012 way cheaper to replace the entire hatch. start now and quit when you find the hatch you want in your color. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 18, 2012 Author Share Posted October 18, 2012 way cheaper to replace the entire hatch. start now and quit when you find the hatch you want in your color. How heavy is the rear hatch? Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 18, 2012 Share Posted October 18, 2012 Free on in Colorado Springs, CO dented at the bottom but the glass is good. Come on out and pick it up. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 18, 2012 Author Share Posted October 18, 2012 (edited) Free on in Colorado Springs, CO dented at the bottom but the glass is good. Come on out and pick it up. Mine got dinted last year.. You know that feeling you get.. It was windy, I happen to look in my rear view and I see a shopping cart headed right for my rear. my friken keys were in my pocket at the time I was so pissed, and the lady I saw gets the cart... I thought about giving her a little scare. So from now on any wind I park far far away. Looking on car part they have some, about $200 or so which is not bad.. I'm going to guess the hatch is around 25-35 lbs? and I assume it wont fit in the rear? Edited October 18, 2012 by 1-3-2-4 Quote Link to comment Share on other sites More sharing options...
edrach Posted October 18, 2012 Share Posted October 18, 2012 Whole hatch is the way to go. But having had to repair 8 broken wires in the harness (at the bend up top), threading the harness down the door pillar is a real pain. It can be done but requires quite a bit of patience. Also if the donor car is significantly older than yours, I'd check the continuity of all the wires in the harness that go around that bend before I install the hatch. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 18, 2012 Author Share Posted October 18, 2012 That's what confuses me I'm not sure where the connection is for the hatch as far as the wire harness, the 3rd brake light I know because I did some custom work on that. I assume the FSM will show a rough location? And the colors for 97 it only had the dark blue right? Quote Link to comment Share on other sites More sharing options...
